Question about Lexmark X4270 All-In-One InkJet Printer
  • 2,785 Answers
Plz try by reloading the printer
Posted on Dec 16, 2008
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
My print spooler is not running
If you are getting a message that your print spooler service is not running, possibly you have the print spooler service turned off.
To start the print spooler service in XP:
Click on Start
Click on Run
Type "services.msc" and hit Enter or press OK
In the services window look for "print spooler service"
Click on the Print spooler and on the top left corner Click on "Start"
Reboot the computer. You should be able to print now.
Please get back for any further assistance.
If you find this resolution helpful, please do not find to leave your comments and ratings.
Thank you for choosing Fixya.
Feb 26, 2010 | Canon PIXMA iP1600 Printer
Print spooler stops / Printers missing from machines
try C:\WINDOWS\System32\spool\PRINTERS
this path in spooler path
Jul 14, 2009 | Ricoh Aficio MP1600SPF Copier
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Print spool service is not Running
What makes you think the print spooler is not working? Is it because you get a message saying that it is not working or is it because you cannot print?
If you can stop and start the print spooler that would indicate to me that the spooler is running and you have a different problem. It is probably a corrupt print job, to fix this do the following.
1) stop the spooler
2) go to My computer
3) select the C drive
4) select the windows folder
5) select the system32 folder
6) select the spool folder
7) select the printers folder
8) delete everything in the printers folder
9) restart the spooler
Sep 30, 2008 | Computers & Internet
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
Hp laserjet 1022
It sounds like an issue with the spooler service on Windows.
You will have to download the tool kit to run it. It states for windows server 2003 but will also work on xp Her is the link fo rthe download:
here is a link with direction for running it on xp
When you run it it will ask you if you are sure you want to delete spooler files. clcik yes. When it asks if you want to delete USB monitor click on no.
Thisis the fix for the print spooler issue after you run the cleanspl.exetool and wipe out all the ports. You have to add back in the USB portmanually.
Run regedit. Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Print/Monitors.Look for a USB Monitor entry. Before doing anything else, backup theregistry entry by right clicking on "Monitors" and selecting "Export".Give it a name and locaction so that you can put it back if you haveproblems later. If "USB Monitor" is not there, add it by right-clickingon Monitors, New, Key. Name the new key "USB Monitor". Once added,right click on the new key and select New, String Value. Name the newvalue "Driver". In the right portion of regedit, right click on the new"Driver" value and select "Modify". Make the value data "usbmon.dll".If there is an "HPUMON" entry (or the like), delete it. Disconnect theUSB cable to the printer. Run the "scrubber" or clean utility, rebootthe machine. Reconnect the printer and install the driver software permanufacturer instuction. This fixed my problem. Good luck!
Mar 12, 2008 | HP LaserJet 1022 Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
