Saxonshardco motherboard issue
Dann i forgot to tell ya ;my drunk sister inlaw got her little paws on the motherboard and started moving jumpers around! so you can see my delemma now>
Get your sister in law to AA, that may prevent future problems happening.
Posted on Jan 07, 2009
My sister inlaw send me a web cam from canada but she forgot something, the cam installer. how can i install it to my computer without the installer?
You can download the driver from the manufacturer's WEB site.
I cannot give you the link to this manufacturer's WEB site because you have not given me the make and model of your WEBcam.
Jan 09, 2011 | Office Equipment & Supplies
Hiw many gallons of water with 2 rinses does a top
Your washer takes 35 gallons to wash and 35 gallons to rinse. Ask me how I know? Well I work on them but last December my washer (which is the same as yours) developed a problem with the cold water inlet valve. My inlaws and daughter and friends all come by at different times to use paws paws washer. They pass 50 laundry mats to come to my house. Just for fun I told my wife to get a 5 gallon bucket and fill the washer up. It takes 7 buckets to fill the washer up and get it to start washing. Later she decided to run a water hose out to the washer and fill it up. Then my mother in law suggested she put the washer on rinse and fill the tub. That told me I had a timer problem. But luckily I have 2 or 3 washers around the house I can get parts off of. So to recap: 70 gallons of water to wash a full load of clothes is what I guesstamate it took. Did that slow down my inlaws? Nope.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | GE WHRE5260E Top Load Washer
Forgot my bios password please help benny
There are a number of reasons why we might set a password to protect our BIOS from changes. The problem is that we only need to go in there once in a blue moon, making the password easy to forget, locking everyone out. I had a situation many years ago where a colleague suggested the purchase of a new motherboard because they couldn’t remember the password. I got that little bit more frustrated with my job that day.
There are various options you can use to get back into your BIOS. All of them reset the BIOS back to default values, so make sure you’ve tried all of your regular passwords before attempting these methods. I have tried to keep it brief…
Newer Computers: Most newer motherboards have a jumper on them, which you can change the position of to reset the BIOS. Find your motherboard manual or search for the motherboards model number in Google. You want to find a diagram showing what and where various components and jumpers are on the motherboard. The manual should tell you which jumper needs to be changed.
Once you have changed the jumper, return the jumper back to its original position while the machine is off. You don’t want it to keep resetting itself. Turn on the machine and go into the BIOS. All options will be open to you.
Older Computers: The quickest way to get into the BIOS of an older computer that has been password protected is to remove the battery. The battery keeps the system clock going. Once you remove it, you can put it back in and start the computer.
When you start your computer, you will find your BIOS has been reset to its default values. You are now able to change any settings you want.
General: Some motherboard manufacturers have a secret password that will work, overwriting the password already locking the computer. These are readily available online with a bit of a search. I think this is becoming less common with time.
For more information on the methods above, tech-faq has a great article which goes more in depth.
Oct 26, 2009 | Acer TravelMate 6593-6656 Notebook
I just asked about removein the startup password wat do mean with the jumper i am new with computers so could u explain a lil more
3ac542afbc4ff40fe47b72448dec8cca.png they look like this and can be any color... Most motherboards can have the BIOS password reset by moving the jumper to the correct pin position. Many motherboards have small print by the jumper to indicate the correct positions. For example you might see some pins on the mother board, with a jumper like the one above, with the words PSWD RST or something similar wrote on the mother board. If the jumper is on pins 1 and 2 move it over to pins 2 and 3, then reboot your computer. Then shut down the computer down and put the jumper back where it was and it should have reset the pass word.
I would advise you to compare my instructions to that of *********** boards manual which you can download form the mother boards manufacturers website.
Sep 11, 2009 | Compaq (283983-001) Motherboard
Forgotten password ASUS P4P800-VM
There is a blue jumper located just below the lithium battery on the motherboard. You need to remove the jumper and move it to the two pins on the right for about 10 seconds to clear the CMOS then move the jumper back to where you found it. That should clear out the password. It will also change all the BIOS settings back to factory so adjustments to the BIOS may need to be made after reset.
Sep 06, 2009 | ASUS P4P800-VM Motherboard
How to install the jumper in normal mode?
If i am correct, the computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position and It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try.
The jumper should look something like this: http://tinyurl.com/l8hvqr
Jun 09, 2009 | Intel DG31PR Motherboard
How to i reset my bios setup sir plz tell me in detail
If you remove the CMOS battery for about 10 sec with the pc unplugged, should clear it, OR
Usually close to the battery (looks like a watch battery), there is a Jumper, with 3 pins labled CMOS Reset, move the jumper to the pins they are not on now and power the PC on and back off, then replace the jumper to the default pins. That will reset Password.
thanks for any ratings
Mar 30, 2009 | Intel D845GVSR Motherboard
Turn off power and reinstall the jumper in normal mode position
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
Need to bypass primary master HDD user password
send me ur email and I'll give you link for software to remove all passwords in bios or windows
Jan 26, 2009 | Dell Inspiron 2650 Notebook
Jumper configuration for motherboard
Matt,
I don't have a solution for you, but tell K. her sister is looking for her, and to give her a call.
-Laura
Jun 27, 2008 | Biostar M7VIQ Motherboard
Computers & Internet Logo
410 people viewed this question
Alun Cox
David Payne
David Payne
