Question about Kenmore 54622 / 54624 Side by Side Refrigerator
Hollow Ice Some of the ice cubes coming out are consistently hollow. It is not all of them. What causes this? We have changed the water filter fairly recently, but can't think of anything else to try. In the grand scheme of things this isn't a big problem, just an annoyance. Thanks!
  • 24 Answers
H-m-m-m. Well, I'm not a chemist or a physics oriented person. My guess is that the air is trapped inside the cube as the ice forms. If there is a fan blowing cold(frigid) air over the cubes in question, it would make sense that the water in the tray would freeze at the coldest point first; that would be the top of the cube as opposed to the point farthest away or the bottom. The temperature of the water would uniform when the water enters the tray but would change in layers (top to bottom) as the cold air draws the heat out of the water (top) and the rest of the tray draws the heat away causing the ice to form through condensation. since the freezing process would occur faster at the top, any air trapped would condense allowing the rest of the water to freeze. Sort of like bubbles under a sheet of ice on a frozen pond. Solution? Are you manually filling the trays or is this an automatic process? If manual, try filling the trays with warm water and check them the next morning. Warm water is supposed to condense faster than cold. You mentioned changing the filter. Is it charcoal? It shouldn't make a difference but the new filter needs to have some water sent through it prior to installing it in the line to remove any loose particles that would end up in your ice. Other than that, adjusting the freezer to a colder temperature is about the only remaining option. Hope this helps. rix20601
Posted on Mar 21, 2007
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 54622 / 54624 Side by Side Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
