Question about Motorola Mobility RAZR V3
Strip lock i have got v3 and its strip lock is broken.what should i do to repair it
    Brigadier General:
  • 7,752 Answers
Take it to a mobile center and have that done.
Posted on Dec 26, 2008
I have a ford 3000 tractor that when you put it in gear and let the clutch out it wont move but if you press the rear differentil lock pedal it will go
You either have one of your rear axles spline stripped or broke, or side diff gear. The diff lock will lock both axles together and pull it self stripped or not. The diff lock will make tractor pull itself but only one wheel is pulling the tractor at this time. Determine which wheel is pulling and which one is not with diff lock on. The one not pulling is the broken side. Disassemble and repair.
Jan 05, 2017 | Ford Garden
Razr v3i flexible strip repairing
We don't recommend self repairs. Contact a mobile repair facility to perform the repair.
Mark
Motorola Support
May 12, 2014 | Motorola Mobility RAZR V3
The screen on my phone is all white and fuzzy. what do i do to fix it?
there are two reason for white screen, first the flexible strip connecting the phone is broken and second the display lcd is defective, any way it needs professional help to replace the flexible strip.
i suggest you take it to a good service centre
Dec 23, 2010 | Motorola Mobility RAZR V3
Tilt steering lock will not stay locked, 0n 04 crv don't have owners manuel can't see any screw or way to tighten it
the part that is broken is deep inside the column
you have to strip the column to repair and this will require a few specific special tools
not something I would recommend for a non-automotive tech due to complexity and the air bag issues
Sep 12, 2010 | 2004 Honda CR-V
Scanner carriage jammed #3 and #6 does nothing.
Check if you haven't moved the scanner lock lever accidentally - find the lock lever (used to immobilize the carriage in transport) and move it to locked position, then to unlocked, and power up your unit. Chances are that the carriage was not dislocated when trying to move while locked, and will start to operate.
If it's not that, it may be a number of things, like broken belt, encoder strip (if any), carriage motor fault - things you won't be able to repair yourself.
Nov 12, 2009 | HP Office Equipment & Supplies
I can't work out how to get an old sim card out of my motorola razr and replace with new one - do I need to remove the battery as it is in the way? and how do I do that?
To release the battery - push down on the battery from the top of the phone and lift it out using the same motion as you used to lift the cover. The SIM will then slide out. Don't try lifting the metal strip covering the SIM, it is part of the locking mechanism and the SIM will not contact properly if this is broken.
Oct 20, 2009 | Motorola Mobility RAZR V3
How do I get the contacts out of RAZR V3?
They should be able to upload them for you to your new phone at the Alltel Store.
Mar 03, 2009 | Motorola Mobility RAZR V3
How to replace broken front glass on razr v3
If this isn't something you have tried before, I would HIGHLY recommend you take the phone and the part to a repair shop. This is a difficult procedure that does require special screwdrivers.
A repair shop will not charge you much for this at all, especially with the part in hand.
Dec 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
