Question about Breadman TR2200C Ultimate Bread Maker
No connection between bread pan and machine
I started the machine and part way through the cycle, it stopped. The engine kept grinding away but would not move the paddle. I took the bottom panel off to see if the belt had broken. It had  not. I gave it a whirl to make sure. I put the pan back in to finish the cycle. A couple washers fell out as I lifted the pan but  I did not see them until later. The cycle finished. When I took the pan out after the bread was done, the part on  the loaf pan which locks into the bottom of the baking chamber  came off. I did not find the clip to hold the part on to the  bottom of the bread pan. I live in Japan so cannot get parts unless I order from the States. Is there a fix without new parts?
3 Suggested Answers
SOURCE: removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Posted on Oct 01, 2008
  • 204 Answers
SOURCE: worn out bread pan
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 06, 2009
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
Looking for recipe for rapid rise white bread
Rapid Cycle White Bread
  • 1-2/3 cups warm tap water
  • 2 tablespoon vegetable oil
  • 4-1/2 cups bread flour or regular white flour
  • 2 tablespoons dry milk powder
  • 1-1/2 teaspoons salt
  • 2 tablespoons sugar
  • 2 teaspoons bread machine yeast
Measure the ingredients into the bread pan in the order listed. Make a well in the flour and sprinkle the yeast into it. Set the machine to it's Rapid or Quick Cycle. On my machine this lasts for 80 minutes, or 1 1/3 hours. Press Start, and let the machine work it's magic. Remove the cooked bread from the pan after baking and allow it to cool before slicing.
Jan 20, 2011 | Black & Decker Bread Machine
Help - the stirrer keeps sticking, the motor strains to turn it round but it won't go when the dough is in, its too heavy. The last loaf I made I had to take the dough out of the machine and kneed it...
Take the bread pan out of the machine and run a kneading cycle. See if the motor is straining. If it is it could be a belt or the motor itself. If the motor runs nice and smooth and you can see the motor shaft spinning effortlessly, then it's the bread pan itself. See if you can spin the paddle easily when it is out of the machine. If not then it is the sealed bearing in the bread pan that is starting to fail and it's time for a new bread pan. Hank
Dec 13, 2009 | Kitchen Appliances - Others
I love my bread machine, model 5890, but with every loaf of bread the kneading blade stays inside the bread. The bread is also difficult to take out of the pan. This has led to scratches in the pan as...
I usually take the paddle out of the machine at the end of the kneading cycle and before the rise cycle. (Do this with the pan out of the machine..just in case). You don't want to use anything in the pan that will scratch it. Usually a few quick taps of the bread pan on the cutting board will free the bread.
Dec 05, 2009 | Sunbeam 5890 ExpressBake Bread Maker
I have the 5890 Sunbeam breadmaker, I love it except for the kneading blade bakes right in the bread, how can you give a loaf away with that in it?
You can take the paddle out of the bread pan after the last kneading cycle and before final rise. Do this rather quickly if you don't have a pause feature so you don't lose any rising time.
Take the bread pan out of the machine, put dough in a bowl, remove paddle, put dough back in pan, put pan back in machine.
Some people suggested to spray a small squirt of olive oil on the shaft to prevent sticking.
Hank
Aug 29, 2009 | Kitchen Appliances - Others
How to remove bread from bread pan
This is model specific. Ask here for user manual for your model.
Jul 22, 2009 | Sunbeam Kitchen Appliances - Others
Bread pan pops out during the kneading 2 cycle
I had a similar problem after using the same machine for several years. It worked well for years and then popped off the shaft whenever I had a rather stilll dough. To solve the problem I bent the clips on each side of the bread pan that hold the pan into the machine up and toward the center of the machine. I did not use any tools to do the bending. It solved the problem. The pan no longer jumps up out of the clips and off of the shaft.
Jun 02, 2009 | Breadman TR2200C Ultimate Bread Maker
Me too! I have to bend the two metal pieces on the sides out before every use - they are pretty flexible, you won't break them. Just bend out and they hold the pan in for a use or two. Not an elegant solution, I admit, but it works.
Dec 31, 2008 | Breadman TR2200C Ultimate Bread Maker
Initial use
YOu want to clean out the interior with a damp (NOT WET) cloth then dry it - before running it empty with the breadpan and paddle in place. My manual told me to follow the instructions for the Making Dough and Baking Bread section of the Instruction Manual. (I have TR5200BC) I'm referencing page 23 of my manual and starting from STEP 5. Comments in { } are mine.
5.Insert the Bread Pan into the Bread Chamber - press down and make sure it snaps securely into place. {note - you may find that you have to rotate what looks like the propeller on the bottom of your bread pan until you get used to placing it the chamber}. If the Bread Pan does not snap securely into place, remove Bread Pan. Wearing oven mits {to avoid sharp edges}, place fingers behind Bread Pan clips and gently pull away from oven wall. Insert Bread Pan again.
6. Close the Lid. Plug into 120V-60Hz outlet. The Breadman will beep and the display indicator will light up with flashing zeros.
7. Press the SELECT Button to choose the Cycle you want. Each time the SELECT Button is pressed, it will beep and the Indicator will move to the next Cycle in the Display Window.
8. {Skip step 8 - Crust selection}
9. Press the LOAF Size Butoon to select 1LB
10. {Skip step 10 - Extras nuts/fruits}
11.Press the START Button
12. Press STOP/RESET Button and open the Lid. {If you want to remove the Bread Pan at this time be sure to use oven mits - I did mine the night before I wanted to use it and let it cool over night. Before I used it to bake I rinsed out the Bread Pan with warm water and mild soap}.
This will take about 2 hours then you are ready to bake. Enjoy
Dec 03, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2500 BC
See my posts on this problem.
Do not mess up the clips.
Aug 21, 2007 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
53 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
