Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
No milk,or steam coming from cappucinno nozzle
I have just done a de-scale and clean of my Impressa Z5 machine. i re-assembled the cappy nozzle and when I press the milk button, the machine makes the thump thump noise that it should before the milk comes from the nozzle but nothing happens - no milk, no steam!
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Posted on Jan 09, 2009
We have managed to fix the problem. The metal nozzle from the machine to the cappy nozzle had a blockage which my husband managed to free, so all fine now.
Posted on Dec 16, 2008
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    https://www.youtube.com/watch?v=HlCu5m9isT4
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    https://www.youtube.com/watch?v=_jF_8rNUn4A
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    https://www.esperanza.ch/.../download_manual_jura_impressa_z5-gen2_...
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
Milk does not come out
remove the milk hose and the dispenser. grab the dial that lets you change between milking a cappuccino and a flat white, pul is straight out of the removed section. You will find slots in the shaft that are choked with milk solids. This happens when CAPPY RINSE is ignored.
Nov 12, 2013 | Jura Impressa X9 Espresso Machine
Jura impressa X7 will no longer pull cleaning fluid, dispense milk or steam
I would like to know more in order to better understand. When any of the steam functions are selected do any errors display? Also, does steam come up through the machine from inside? It could also be that a solenoid valve (electronic valve that can operate flow) may be bad. It almost sounds like the problem you have may be coincidental with the hose incident and now it's a little harder to diagnose.
Apr 10, 2012 | Jura Capresso Impressa X7 Espresso Machine
The steam nozzle has broken
Yes you can but it is very hard to get inside the front of the machine if the tube has come off in the front panel, if it has come off one of the solinoids in the right hand side of the machine it is easy to put back on also check that the steam nozzle is not blocked with old milk it will cause the pressure to blow off the tubes
Jun 26, 2010 | Jura Capresso Impressa S9 Coffee...
My jura impressa z5 is having trouble foaming the milk...worked fine last season but we can't seem to get it foaming the same as it was before...suggestions??
The common cause is that the frothing connection is faulty. You can look at the Guide to clean the Jura frothing connection, or try this. Take some bicarb or vinegar, dissolve in 400ml luke warm water, select cappuccino maintenance under the options, or press the milk button. Run the complete mixture through then. Run about 600ml of plain water through the spout. Turn the sport from froth to milk and back every 10 seconds.
If this does not work, then there may be a need to decal the machine.
Jan 24, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Weak steam flow from milk frothing wand.
This is usually a sign it needs a de-scale. you can get a de-scale solution from most coffee machine retailers. Vinegar can be to harsh and ruin your seals. After frothing your milk make sure you let some steam through without milk to clear milk that can be sucked up wand. You can get cleaning instructions of Saeco web site. Good luck
Sep 10, 2009 | Saeco VIA Venezia
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
519 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
