Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
Whirlpool modle ET1CHMXKQO2
Yes drain tube is frozen,cant open back it is sealed by brads. any other solutions !!!!!!!!!!!!!!!
    President:
  • 1,462 Answers
Boiling water and patience
Posted on Mar 21, 2007
    Problem Solver:
  • 11 Answers
If you cant get to the back the only thing left to do is unplug fridge until drain line defrosts
My whirlpool CB239W fridge is not draining condensed water away
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 22, 2015 | Whirlpool Refrigerators
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
There is copper tubing at the back of freezer. The copper tube that goes from the compressor up into the refrigerator is covered with a layer of ice. Eventually this breaks off when it starts to melf and...
Hello, Thank You for using FixYa. I will be helping you today.Yes this can be a sealed system issue. There is either a leak or a restriction in the system. Some units have a ten year warranty on sealed systems check your warranty to find out.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | Refrigerators
I think i have a frozen drain tube. water is leaking from the freezer into the refrigerator. i can not find the drain tube. can you tell me where it (the drain tube) is located and how i can access it. ...
Yes you can get to it from the inside. There should be screws in the back towards the bottom of the freezer that wiil let you remove the bottom of the freezer compartment. Under tere you will see the drain hole and the freezer coils, alond with the defrost coil.
Then checkout this tip to help you make it so the hole won't freeze shut again...
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Apr 22, 2010 | Whirlpool ET1FTKXK Top Freezer...
Water collects inside the frig
usually an indication that the drain tube is clogged with frozen water or blocked woth something clean the drain tube.
Mar 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
WHY IS THERE ALWAYS ICE ON THE BOTTOM OF THE FREEZER.IT GETS TO BE SO THICK THAT THE DOOR DOESN'T SEAL?
You have a frozen drain. Remove the cover on the bottom back and locate the drain tube and thaw it with a hair dryer. Find the drain inside the fridge and run hot water thru it until it opens.
Oct 26, 2009 | LG LRBN22510WW Bottom Freezer Refrigerator
I cant figure out how to stop water from draining it say open close on it the modle is catherine 60 spacesaver with integral skirt
the seal on the drain is gone bad ot the mechanism is broke. Replace the drain and/or mechanism
Jul 22, 2009 | Home
I have two whirlpool refrigerators. Both have the same problem. The defrost drain and drain pan under the evaporator coil freeze. Then the defrost cycle causes water to drip down into the frig section. At...
Under the cabinet in the back is a drain tube with a loop for air seal. this loop will sometimes become plugged. Clean it and it may resolve your problem. I use a small section of automobile speedometer cable as a mini roto rooter.
May 03, 2008 | Refrigerators
Ice & water dripping in refrigerator
ok your defrost drain is frozen take the back panel off in the freezer section under the coils you will see a silver pan if its frozen it will be a block of ice you have to remove the ice then make sure the drain and tube are clear all the way to the pan at the bottom you should see the plastic tube on the back of the unit in the center over time algae can grow in the tube blocking it drying the unit will help but soon as it defrosts the tube fill up again and the problem reoccurs you kinda got to snake it out so to speak.the best way to deal with it is to go to lowes or home depot and get a eurka 302 enviro hand held steamer an investment but a great product to have around the house cost about 40 bucks but 1000s of uses
Feb 13, 2008 | Refrigerators
ET1CHMXKQ02 TOP FREEZER REF.
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Mar 17, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
