Question about Harman Kardon AVR 520 Receiver
Creating a surround sound system
I have a H.K. 520 receiver, 2 klipsch KSB 2.1 speakers, a velodyne CT150 sub, a polk audio center speaker, a sony bdp s301 blu ray player and a 50" panasonic plasma tv. Can I hook this stuff up to make a decent sounding surround sound system"
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 16, 2008
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I hooked up my newly purchased Sony BDP-S560 with HDMI to my projector for video, optical cable to my Yamaha RX-V750 for audio. I tried several audio setting with the BDP-S560. However,I cannot get any...
It sounds like the BDP unit is set to downmix PCM to the Optical Digital Audio output (the default). You need to change it to something like Dolby Digital. Crack the manual and look at all the digital audio settings you need to choose.
Aug 04, 2010 | Sony STR-DG510 Receiver
Onkyo 6.1, 75 watts connected to sony blue-ray.quality sound not there maybe because I have it connected to reg. stereo speakers with klipsch center speaker.If so, what speakers work good? Iam on a...
How much of this scenario is NEW?
Within limits: Speakers is speakers. They don't know how many other channels are there, so their sound quality is independent of each other. Send them good sound and they will reproduce it.
Improper setup will hurt the 'sound' as much as poor speakers.
Not knowing what you have for speakers now, I would advise you might get yourself somethingto serve as a sub an some surround speakers before you declare your current speakers faulty.
Mar 31, 2010 | Audio Players & Recorders
Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Mar 26, 2010 | Polk Audio PSW10 Subwoofer
Hey , with the Onkyo TX-NR1000 can I get started plugging two speaker while I gather enough money to buy the surround sound speakers. Also your opinion on speaker choices is greatly appreciated. Thank you.
Sure you can only connect 2 speakers. As for brand recommendation Polk audio makes some fine sounding speakers also Klipsch, Boston acoustics, too many to suggest. If you have a Best Buy near you they usually have a speaker room with many different brands that you can listen to. Though that doesn't mean you have to buy them their. I'm partial to Polk audio though. Polk has excellent customer service. That's going to be a tough decision you should really do some research on the internet for cost to quality references. Good luck. I hope this gets you pointed in the right direction.
Nov 24, 2009 | Onkyo TX-NR1000 Receiver
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Harman Kardon AVR 520 Receiver Logo
324 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
