Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
RYOBI TRIMMER i need to replace the primer bulb for trimmer RGT2500 where can i get 1 ?
  • 8,197 Answers
Here you go. this is the site that you need.
http://www.psep.biz/store/walbro_primer_bulbs.htm
Posted on Dec 16, 2008
Why is Ryobi trimmer primer bulb not drawing fuel?
Check the bulb to see if it is cracked, allowing air to get inside. If the bulb has lost its flexibility you might need to purchase and install a replacement bulb. It is a simple operation.
Sep 20, 2014 | Ryobi Garden
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have a 26cc ryobi weed trimmer--primer bulb will not draw fuel, but will draw fuel when I loosen the 2 screws that hold down the bulb
Possible issues:
1. Primer bulb or bottom assembly has crack or hole in it (needs replacing). See ebay for about $6.00
2. Fuel lines are not sealing to the primer nipples properly (cut line and re-attach if you have sufficient line available) otherwise; replace.
3. You may be somehow kinking the fuel lines when you clip it back in place due to fuel lines too short
My bet: #1 or #2. Good luck!
Sep 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer bulb will not fill on Ryobi 775R
There are aprox 5 sizes of primer bulbs that are common to trimmers, blowers, saws. You will need to be specific about carburetor brand and type when looking for a bulb. A small engine repair shop should have access to any of them.
Nov 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
My prime button broke can i bypass it
No, you cannot bypass it. Even if you could get it to run without the bulb there would be a significant chance of fire and injury. Replacement Ryobi primer bulbs are very common, you can get one just about anywhere...in fact, you can go to Google, put in Ryobi and whatever the model number is of your trimmer and the words primer bulb and you will get plenty of hits for parts companies that carry the replacement bulb.
Sep 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer sticks in on gas trimmer
Primer bulb assembly should unscrew. If you do that and then replace it back on the unit does it do it again? Seems that a vacuum is forming in the primer bulb. Reed valve could need cleaning.
Jul 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need a fuel line and a primer fuel pump (plastic bubble) for my Ryobi 31cc trimmer plus. Any idea where I can get the parts?
You can order them directly through Ryobi and pay a small fortune or you can go to any small engine repair shop and purchase the fuel line by the foot. I believe your primer bulb can easily be replaced with what your local shop will have in stock. The parts from your local shop will probably out last the factory parts anyway.
Mar 08, 2009 | Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
131 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
