Question about Harman Kardon HK695 Computer Speakers
MAKING A SURROUND SOUND SYSTEM
I have a Harmon Kardon AVR 520 receiver, 2 klipsch ksb 2.1 speakers, a velodyne CT 150 subwoofer, a polk audio center speaker and sony BDP S301 blu ray player. Can a create some kind of surround sound system with these pieces? The audio part is left overs from audio system I've up graded. My audio system is 2 channel and set up for mostly vinyl. (Conrad Johnson Pre and amp, project 10 turntable, and dynaudio speakers).
Would it sound good enough to mess with it? (TV is 50'' panasonic). Many thanks my friends.
madansakre
  • 51 Answers
SOURCE: Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
Posted on Jan 04, 2008
Benimur
  • 6966 Answers
SOURCE: creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 16, 2008
SOURCE: harmon/kardon computer speakers not working, light on, no sound
I have my own resopurce already but the thing is you need to spend money for the repair. I contacted a service engineer for the unit and they sy it can be repaired.
Posted on Feb 04, 2009
sergiomc1
SOURCE: Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Posted on May 09, 2009
SOURCE: How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
Posted on Jun 09, 2009
How to bi wire polk rti a7 using avr 1600 harmon kardon reciever
You mean "buy-wiring"?
Before you go investing in boutique speaker cable (times two) read up on biwiring.
It's a bogus electrical theory to get you to buy more speaker wire.
http://en.wikipedia.org/wiki/Bi-wiring
I don't see that capacity on this receiver.
http://www.theaudiocritic.com/downloads/article_1.pdf
Jun 24, 2011 | Polk Audio RTi A7 Main / Stereo Speaker
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Jun 06, 2010 | Boston Acoustics PV800 Subwoofer
I have a Harmon Kardon-AVR 320, DVD 25, PA 2000. I can't get any sound with when trying to watch a DVD. I've tried every setting on each system. The L and R speaker light blink on the DVD setting. The...
We have this same problem We had friend visiting; he pushed a button and we've lost sound but only on the dvd. I've tried every setting I can think of, but can't get sound. Did you find a solution?
Dec 27, 2009 | Harman Kardon AVR 320 Receiver
I have a bose v20 and a harmon kardon receiver. Should I be returning the bose system, buy just the speakers, and and outside subwoofer, or what is the best system for watching movies etc? What would be...
If you have the harmon kardon receiver, check out this reasonably priced system. You can actually find it cheaper than at this website but I have these speakers and, when paired with the Klipsch sub-woofer, it makes movie watching an unbelievable experience.
http://www.klipsch.com/na-en/products/quintet-sl-home-theater-system-overview/
Good Luck!
Oct 19, 2009 | Bose 901 VI Main / Stereo Speaker
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Apr 04, 2009 | Audio Players & Recorders
Creating a surround sound system
Dec 16, 2008 | Harman Kardon AVR 520 Receiver
Harman Kardon HK695 Computer Speakers Logo
80 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
