Question about Refrigerators
Reset after water filter replacement
I have just replaced my water filter in accordance with the owners manual after the 'Filter' warning appeared on my fridge door. However, once replaced, the warning is still active and now , 2 weeks later, the automatic shut off has activated so that we cannot get any water from the fridge.
The manual does not tell me how to reset the function following filter replacement and Hoover will only send an engineer to look at it and apply minimum call out charge. Can you help?
  • Anonymous Mar 29, 2014
    the lcd screen keeps telling me replace it but I did replace it and it stills keeps buzzing!
    Scholar:
  • 111 Answers
Generally all you need to do is push and hold the filter reset button in for 3 to 5 seconds to reset it. However, even with the filter light on, it shouldn't stop the water flow as most of the time on most brands it is just an "idiot light" that is on either a timer based on number of days or on number of minutes the water has flowed through the water valve
Posted on Dec 16, 2008
Try disconnecting the fridge from the wall. Wait 30 seconds and plug it back in. This MAY reeset the system.
Posted on Feb 20, 2009
Our fridge is beeping every time we open it
Check the owner's manual or Google for one. Check to see the interval in which you should be replacing the water filter. Water Filters can usually be purchased where you purchased your fridge or a big box hardware store for around $30-$40. In most cases, you should be able to reset the water filter alarm to clear the beep w/o replacing the filter.
Sep 23, 2016 | Refrigerators
Showing that water filter needs replacing, I don't have a water filter in it.
The filter light is just a timer, reset the the filter light accordung to the owner manual or just ignore it.
Mar 15, 2015 | Refrigerators
THe filter light will not go out on our Samsung RF266.
If memory serves, you put your finger on & hold the filter warning indicator for 3+ seconds and that will reset it after the filter is replaced. I've temporarily misplaced my owner's manual to confirm for certain.
Sep 08, 2014 | Samsung Refrigerators
Change the water filter
I believe that this is an automatic warning to get you to replace the inline water filter located in the back of the refrigerator side up near the top. This sells water filters at 30+ dollars a pop. There is a procedure in your manual to replace the filter, but you could just reset the warning by holding the "filter reset button" for 3 seconds. that button is on the front door of the machine.
Jun 13, 2014 | KitchenAid Superba KSRG25FK Side by Side...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water filter warning light has come on
Hello. When the water filter warning light comes on it is time to replace the water filter. Once the filter is replaced you will have to reset the warning light. To do that Hold the Lock/Unlock Button and the Water Dispensing Button for (3) Seconds. The Change Filter Light will Blink and Reset. Joe
please rate my answer as very helpful. Thanks.
Apr 21, 2010 | Maytag MSD2756GES Side by Side...
How to remove water filter on Whirlpool ED2VHEXVQ00
the filter is located in the front of the unit just below the freezer door whirlppol has 2 filter options one has a push button next to the round filter cartridge that whne pushed releases the filter. the other option is a twist out filter simply turn 1/4 tun counter cloclkwise and the filter will come right out.
after replacing filter run aprox 1/2 gal of water to clear air and remember to reset filter monitor according to your owners manual
Jan 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Water filter
The red warning light has to be reset manually - by pressing the Ice Type and Child Lock buttons together for 5 seconds. As for the taste, check the flow direction is correct on the filter and run a few litres of water off.
Apr 16, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
641 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
