Question about Motorola Mobility RAZR V3
Storage Device I have a motorola razr and a storage device. I cannot get my phone to recognize it though. I can go to the media gallery and to the sounds option but when i push the select button nothing happens. I cannot switch over to the storage device and want to listen to the songs that are on the storage device. Can you help me?
  • 1 more comment
  • Lacy Brown Mar 21, 2007
    thanks for your help, that worked great!
  • joey41 Nov 04, 2007
    i dont know how to open memory card to see whats on it with my razor
  • Anonymous Mar 27, 2014
    Whenever i switch on the phone device always ask please say a command or name and after that i can't perform any function and i have the only option that is switch off the phone.
It sounds like the memory card that you are trying to get the razar to open is using a different file extension :format: than the one that the razor actually can understand the fix is to "REFORMAT" the SD card but remember to backup any files or data that is on the sd card because once you reformat the data, ect. is gone..
Posted on Mar 21, 2007
Why when I try to go to gallery and get message "no external storage available"
Probably you are having some syncing issues, have you tried to turn your phone off and then back on and see if that helps?
You can also try to force stop the gallery and then try to open it back, to do that you just need to follow these steps:
Open your Application Tray
Then go to Settings
Once you are there go to Apps>All Apps
Search for Gallery
Select it
Then select the options: clear cache, and force stop
Turn your phone off and then back on.
You can also check the troubleshooter website on Motorola.com here: Motorola Support Find Answers Motorola Mobility Inc
Best Regards!
Jun 12, 2014 | Motorola Mobility Droid RAZR HD
How do I download pictures from my motorzar phone to PC . I connected my phone to PC and it downloaded motorola driver. Now what do I do
You must configure the phone as a Mass Storage device and then connect to the PC. It will be recognized as an additional drive. Use it as you want.
Nov 19, 2009 | Motorola Mobility RAZR V3
My phone doesn't recognize my memory card
the memory card you inserted is not functioning properly insert an other card if it does the same then get your set checked
Aug 18, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How do i change the ringtone for my incoming textmessages?
Press the Center Select Key Scroll to and Select Media Gallery Scroll to and Select Sounds If necessary, press Options Select Switch to Storage Device Select Phone Scroll to the desired file Press Options Scroll to and Select Assign as Ringtone
Jun 10, 2009 | Motorola Cell Phones
TRANSFORMIN PHOTOS FROM OLD CELLL PHONE
How can I transfer files between my PC and my phone? space.gif space.gif answer.gif To tranfer files between your PC and your phone:
  1. Your phone can upload and download files when connected to a PC running Windows 2000 and higher. Mac is not supported.
  2. Open the flip and turn the phone on.
  3. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  4. On your phone, press Yes to use the phone as a portable USB storage device.
  5. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon
  6. Double click the Mass Storage Device icon.
  7. Drag and drop files between your computer and phone
  8. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware" icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  9. Select USB Mass Storage Device and click OK.
  10. Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts.
Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
Oct 21, 2008 | Motorola Mobility RAZR V3
Getting music from memory card
Hey Green-e,
I think ur problem is lack of knoledge to identify the type of data storages device.
There are two types of storage devices: 1) MMC(memory card)
2) Phone memory
When u enter menu->multimedia->sounds, there is a list of sound tracks, ringtones, etc.
In ur cellphone, u may have used Phone memory or memory card as default storage device. If u hv used phone memory, then change to MMC and if u hv used MMC, then change to phone memory.
TO change the storage device.
In sounds (where sounds,ringtones, appears), press menu button (above directional keys). Now u will see a list of options. There u can see storage device. Press on it and change it as u want (MMC or phone memory).
Kindly send me feedback and rate my solution
Be sure to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3
To view your V3r as mass storage device
pressMenu>Setting>connection>SelectUSB Mass Storage
before you connect it in your PC
Jan 17, 2008 | Motorola Mobility RAZR V3
Phone not recognizing memory card???
try to formatt your memory card in PC...
if youll having the same prob. need to replace it.
Dec 31, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Now I can not find the memory card to transfer, download..etc.
you will need to install the pc Mobile Phone Tools Software 5.0 to correct this problem
Memory card for motorola razr
younigleigh: To access your card you have to change the Storage Device. For example if you want to access your RINGTONES or SOUNDS, do as follows: 1. Go to MY STUFF menu by pressing the CIRCLED button betten the GREEN (SEND CALL) and the RED (ON/OFF) buttons. 2. Select for example SOUNDS. 3. Hit the middle multiple bar between the BACK and GO TO options on screen (SOUNDS MENU). 4. Select SWITCH STORAGE DEVICE and select the CARD option. You're now accessing and STORING data on your MEMORY CARD. SithPitt
Jul 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
97 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
