Question about Olympus Camedia C-700 Ultra Zoom Digital Camera
Olympus C3000 fuse blown?
Hi, I connected the camera to a power supply which might have been set to a too high voltage. Now there is no reaction of the camera whatsoever (with batteries or with the correct power suppy). I believe that there must be a fuse somewhere in the circuit which might have blown. Does anybody know where it could be? The camera was working perfectly and I do not want to throw it off. Thanx, D.
  • 1 more comment
  • dieter_blaas Dec 17, 2008
    Hi, I do not know how to post the answer to diddydaveh's question (there are only two options):
    I measured the voltage and it was more than 50V. So, if there is a fuse it was blown. Dieter
    Hi diddydaveh,
    when the camera did not react upon connecting the power supply I measured the voltage, which was about 50V. So, clearly, if there is a fuse it will have blown. I do not know how this happened because the power supply appeared fine. Now, using the correct one there is no reaction of the camera whatsoever. Thanks for hints, D-E
  • diddydaveh
    diddydaveh May 11, 2010
    Hi, how mush difference in the voltage recommended by olympus and the one you used?
  • 154 Answers
I'm afraid that I think your camera is now 'unrepairable' your last option is now to send it back to Olympus, or a camera repair shop for a formal checking and report. If you are insured for accidental damage on your home insurance you may be able to claim thDave Harpere replacement on that if the camera proves to be totallt gone - and they may want a report on it. Sorry to be the bringer of bad news.
Posted on Dec 17, 2008
I have a Sharp VC-H982 VCR. Went to turn on today and it is not getting any power. Worked fine last night. I have moved the power cord to a different receptical, still nothing. Is there a fuse that may...
Hi:
If the unit is totally dead meaning no standbye light of or nothing on the display its dark, then you may of blown the AC line fuse. This is the first thing to check the fuse is inside the unit you can trace its location by taking off the top of the VCR and tracing the pwr cord to the point where it connects to the power supply, here is where you will find the AC line fuse use a ohm meter set on continunity to check the fuse for open condintion. If open or blown replace with same voltage and Amperage rating as indicated on the board or the fuse itself. If you find the fuse is good then you have a power supply standbye voltage missing and is related to the power supply. In which case it may be cheaper to just purchase another.
May 28, 2011 | Sharp VC-H982U VHS VCR
My Sony Bravia LCD TV Got 220v Wile It Should Get 110v,And Went Off
hi...if you have plug the TV in 22oV instead of 11V..it automatically blown the fuse..the power supply has this Varistor it will shorted and blown the fuse if detected high voltage....I suggest you replace the fuse and check for any other defective parts in the power supply section....check for bloated capacitors.. shorted power switching transistor... if none TEST RUN..let see if your TV will switch ON...please rate and vote...
Feb 17, 2011 | Televison & Video
Ref: Philips LCD DVB 26"
You have a diode arrangement in your power supply that converts the AC power to DC power so that it can be stepped up to operate the high voltage power supply of the set. If those diodes are blown, which happens frequently in a storm, then you have no voltage to your high voltage. You are going to have to check that diode arrangement by making a continuity check both ways on each diode. A diode blocks voltage one way but lets it pass the other way, thus producing a DC voltage.
Feb 03, 2011 | Philips 26PF5521D 26 in. HD-Ready LCD...
No power no standby light or nothing
Please check your fuse for blown and power cable for kinks or loose connection.
Feb 01, 2011 | LG 42LC2D 42 in. LCD HDTV
My camedia Olympus c3000 won't turn on with brand new charged batteries.
TROUBLESHOOTING
OPERATING PROBLEMS
The camera does not work.
1 The power is OFF.
[ Set the Mode dial to turn on the power. (P. 36)
2 The batteries are loaded incorrectly.
[ Reload the batteries correctly. (P. 28)
3 The batteries are exhausted.
[Replace the batteries with new ones. (P. 28)
4 The batteries are temporarily unable to function.
[Keep the batteries warm while using the camera.
5 Power has shut off to conserve battery consumption.
[Operate the shutter button or the zoom lever.
6 It is connected to a personal computer.
[The camera will not operate while it is connected to a personal
computer.
Jul 14, 2010 | Cameras
Power problem
Sorry to say as per your info may be you make some mistake to give power supply. High voltage and your camera transformer rosted. Batter visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Olympus Camedia E-10 Digital Camera
Cannon Olympus Camedia C3000 Zoom
Hi - You can download the manual from the link underlined in blue below:
Camedia C3000
It's in 3 parts
More info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 26, 2008 | Olympus C-3000 Zoom Digital Camera
Flash not working
The flash tube or the circuit could be burned out as it is fairly high voltage.
if the tube is black then its blown
Mar 11, 2008 | Olympus FE-230 Digital Camera
Tv Is not respondind
This denotes a problem with the power supply either the low voltage power supply of the high voltage power supply. You will need the following documents and equipment if you plan on doing this yourself: 1) a schematic diagram 2) a Multimeter 3) an oscilloscope 4) a signal generator (color bar, cross hatch, and purity) The schematic will let you know where the test points are and the level of voltage and signal are supposed o be at the test point. The multimeter will allow you to trace and measure DC and AC voltages throughout the set. The oscilloscope will allow you to view the waveforms generated by the signal generator, this is needed to tell if a component is not processing the signal in the proper fashion. The signal generator creates a standard reference to measure by. Since this prolem is in the power supply section you should determine if the problem is a blown fuse by visually inspecting the fuse. Than you will need to determine if the problem is in the high voltage power supply. You do this by checking the transistors in the horizontal section of the TV. you will find the problem either in the low or high voltage power supplies.
Oct 01, 2007 | Televison & Video
Olympus Camedia C-700 Ultra Zoom Digital Camera Logo
66 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
