Question about Motorola AXU4100 (10 Channels) 2-Way Radio
How to set the new channel you wnat on the avx5100 radio
I was able to figure out how to change the channel, but i dont know how to set the channel.
  • Motorola Master
  • 1,655 Answers
Here is a link to the user manual: http://www.123radios.com/Manuals/AXSeriesManual.pdf. Programming is explained on page 2.
Posted on Dec 17, 2008
  • eradiostore
    eradiostore Dec 17, 2008
    I have researched the AXU4100, and it is a dealer programmable unit. The only user programming features are listed in the manual posted. If you are needing frequencies programmed other than the standard programmed ones, you will need to have the unit programmed at an authorized Motorola dealer. This generally cost between $15 and $25 US.
How to figure out settings and swr on a galaxy dx44
whats to figure out? You set the radio on channel 1 adjust the knob to read for check then adjust to set then move knob to swr and write down your reading.Do the same thing on channel 40 and 19 always writing down your reading.
Dec 28, 2012 | Galaxy Radios DX-949 40-Channels Base CB...
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
How do i change the channel?
Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies. Figure 16.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Trouble adding frequencies
first press man, then the channel number you want to fill, then man again, then pgm or program, type in the frequency, and hit enter ( could E or ent). next repeat this process for the next channel you want to program.
Nov 15, 2008 | Radio Shack Radio Communications
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Resseting the preset channels
Please download user manual of Aiwa XR-MN5 from here. This will help you to set new stations presets.
Oct 11, 2008 | Aiwa CA-DW235 Boombox
Radio Shack Pro Scanner
I know that if you turn your scanner off over a few days you can loose your frequency # or it will lock the channels out. if they or l/o just unlock then. I also know that all police and ect. went digital, you would to have a scanner that is digital. When they changed to digital some for the frequency # have changed. I had to get the new ones and put them in.
k.ditterline@yahoo.com
Jun 08, 2008 | Radio Shack Pro-97 Handheld Scanner
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Tone on channels 5-15
I have worked on the TK 3101's and that tone is when the channel does not have a frequency.
It is a PC programmable radio. I assume you purchased the radio used and the previous owner had channels 5-15 "blank"
I can program it for you if you needed.
Nov 05, 2006 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Motorola AXU4100 (10 Channels) 2-Way Radio Logo
369 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
