Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I have four new drives that i am going to hook onto a hard drive controller that supports four drives but am wondering if i should set the frist drive to master and the rest of the drives to slave and also if i should partition frist drive as primary startable and the last three drives as extended partions for drive letters d,e,f
  • 3 Answers
Please provide more info....what is controller brand/model, what operating system are you going to install and what type drives are they, PATA (aka IDE) or SATA?
Posted on Dec 17, 2008
How do you do a faction resat on a dell computer it is a dell computer I got it brand new wind windows 7 came out with windows 7
Find support information for Windows operating systems by Calling Dell Support toll-free number +1-800-204-4427 and get support for windows 7, and much more ... http://www.delltechnicalsupportphonenumbers.com/windows-7-support-number
Jun 23, 2017 | Dell Computers & Internet
Repair broken
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
Dec 28, 2013 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
I need to hook up the external hard drive to my computer to get my favorites loaded back onto my computer. How do I do that?
Connect the external hard drive to your computer using a usb cable. Then go to 'my computer' on your pc, click it, you would see your external hard drive. Open it. Go to the location of your favourites on the hard drive. Right click on it. Select 'send to', then select 'my documents' to send it to your documents.
To unplug your hard drive, dont just pull it out. Go to the bottom right corner of your pc. Click on the notification icon. Hover the mouse pointer over each one of them till you see the one labelled 'safely remove external device'. Click on it, then click on your hard drive name. When you see displayed 'you can now safely remove external device', then unplug your cable from the pc and the drive. To access what you transfered to your pc from the hard drive, go to 'my documents'.
Hope that was helpful?
Have a wonderful day.
Jun 27, 2011 | Computers & Internet
I have a r710dell server. It has two 146GB 15K RPM Serial-Attach SCSI 3Gbps 3.5in Hotplug Hard Drives. It seems like only one is being read. Because the C:\ is only 136GB. What could be the issue?
The two drives could be "mirrored" -- everything written onto one drive is also identically written onto the other drive. Thus, if one of the "set" of mirrored drives failed, you just remove the "dead" drive, insert a new drive, and tell it to "rebuild" the "set" of mirrored drives, i.e., it copies everything from the "good" drive onto the "new" drive, and then the "mirroring" will continue.
Dec 17, 2010 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
When installing a Maxtor Quantum Fireball Plus AS 20.5-GB hard drive as a second drive on a PC. You want the drive to be the slave drive, and you know what that you must change the current jumper settings....
DS=drive select meaning selected drive by the bios CS=Cable select meaning if you hook it to the second plug so set the jumper to CS and hook drive to the second cable if its is ide drive which that is what it sounds like the drive is!!
Jul 21, 2017 | Quantum Fireball Plus AS (QMP20000AS-A)...
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
Data support
IF the sandisk is not formatted as Fat32 then the new PS3s will not recognize it. To format to fat32 follow these steps:
1. Transfer all the data onto a PC or another thumb drive.
2. go to START, CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, and select DISK MANAGER on the left hand side options. Select the external drive and read the "File System" type. If it says "NTFS", right click the disk and select "Delete Partition".
3. Reformat the drive as FAT32
4. Once you are SURE the partition is FAT32, open "My Computer" and double-click on your empty external hard drive. Now, you will want to create a folder system identical to that on the Playstation 3. Right click to create a new folder and name the first folder "Photo". Do this for "Music", "Video" and "Game". When you are finished, you should have 4 folders total in the hard drive. Each folder should (at this point) be empty.
5. Now transfer your saved information into the correct folders, safely remove the drive, and you are ready to go.
Jul 23, 2008 | Sony Playstation 3 (PS3) Console
MoBo Replacement
did you go into the new bios and check to make sure you have the hard drive setting on auto, then check your boot order that the drive is first to boot., if that doesnt work create a floppy boot disk (google it) and see if you see the hard drive when you do that.
Feb 15, 2008 | Computers & Internet
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
37 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
