While watching tv at normal volume, my KLH subwoofer started to make a loud buzzing humming sound. I checked connections and wires, all good. I disconnected and placed subwoofer on table and under light to get better view. I then plugged in power cord and turned it on and same noise occurs. Took speaker out of enclosure and connected it to normal stereo output and it sounds ok. Could this be a power transformer problem or blown speaker? I did'nt think a blown speaker would still sound normal or does it? KLH model HTA 4906 six speaker surround sound system, powered subwoofer
connections are right, it is RCA. Tried different outlet and still same noise. I am starting to think it is a blown speaker, just not sure. Is there a way to test it ?connections are right, it is RCA. Tried different outlet and still same noise. I am starting to think it is a blown speaker, just not sure. Is there a way to test it ?
You can't post conmments that contain an email address.
Re: loud humming buzzing sound coming from subwoofer
That sounds like a bad plate amp. You may be better off getting a new sub if that is the case -it will cost more to repair than to get a used one from Craigslist.
Check the back side of your equipment. You may have be picking up hum because wires (power, speaker, etc) are placed, or fell, on top of the receiver. If they are, try rearranging things to be as uncluttered as possible, and not on top, or against any A/V equipment.
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1] If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
