Question about Fuji FinePix A345 Digital Camera
Blurry screen i took this camera to camp with me and when i pulled it out 1 day there was very little resolution,everything else worked though.how should i fix this?
    Genius:
  • 2,985 Answers
It may be Damp. Remove batteries Put camera in a snap shut Poly bag with a cloth[handkerchief knotted] of rice or salt and place in a warm place for a few days. See if that does the trick. Then come back
Posted on Jul 21, 2007
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
LENS AUTO FOCUS NOT WORKING
Gee I have one of these. Nice camera too.
Check you don't have the auto focus switch on the left side of the lens barrel switched to manual. I've knocked that switch when getting it out of my bag and it took me a minute to find the fault. Very easily knocked so keep an eye on it. Go through your menu and make sure everything is as it should be. If everything checks out I'm afraid it's a Sony repair agent you'll be saying hello to. I wouldn't advise trying to pull it apart yourself unles you are confident. I pulled my second one apart and had a great time getting it all alighned to put back together. Mainly because I pulled it down one week and waited another 3 weeks until I tried reassembling it. Always try to reassemble straight after fixing it. Don't give that brain time to forget important parts and where they go.
If there is a fault it would be in the lens area but after owning 2 of them and the 818s I found no problems in this area and never had a customer have any problems there either. But there's always a first time.
Try that darned switch first though. One other thing it's just possible to try. Make sure your battery is fully charged and in good health. They can cause some weird faults if the voltage is getting low. The focus motor does draw a bit of current.
There's another thought. If the auto/manual switch isn't the culprit. Actually switch it to manual and see if you can focus it by hand. If you can't then it's definitely something major and one last thing. Check your Diopter.The little adjustment alongside the viewfinder. If this is out of adjustment it will give an out of focus blurry look too.
If this has been of any help would you mind letting me know what the exact fault was. It will come in handy with mine. Thanks and good luck
Apr 23, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
May 11, 2008 | Samsung Digimax L730 Digital Camera
98379 Sakar Digital camera
The crop setting you selected & used may be too low in size and resolution which is meant for web application.
Mar 30, 2008 | Sakar 90379 Digital Camera
Toshiba A105 Laptop Screen blurry and iconcs mishaped
Go to the display properties control panel and move the resolution slider all the way to the right. Sounds like you are set in a non widescreen display mode. I think your model has a native resolution of 1280X800.
Jan 29, 2008 | Toshiba Satellite A105 Notebook
Casio Exlim--camera
i have an exilim camera too the 7.2 pixle. And im having same problem the day before i took really clear pix and now its just all blurry ... everything else works fine .. i never droped it or wet it .. i view the old pics and there really clear why is my lense sooo blurry now? help
Dec 20, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Help! My flash isn't working!
1 The flash- with the camera shut down take the batteries out. leave an hour. put them back in. Now - switch on and go to flash mode. Hold the camera to your ear.Can you hear a slight hgih pitched whine? This is the capacitor charging up. If you did not hear it then the flash unit is dead. But to be sure- read the manual and make sure you have set it up and operating it correctly. Blurry picture are something else[possibly] Check that you have not inadvertantly got the camera set to MACRO mode[this may also affect the flash inability. A good reread of the manual will do little harm and check out all those controls again.
May 19, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Lens/ resolution problem
I you have been on a beach there are chances that your camera get get sand inside. you have to get it cleaned before use. to not try to operate the camera in the same condition.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Fuji FinePix A345 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
