Question about Compaq Presario C700T Notebook
Windows not detecting hard disk
I had installed rhel 4 AS OS in compaq c700.
now i am trying to load windows 2003 but hard disk is not detecting.
    Brigadier General:
  • 5,158 Answers
Rhel ? redhat linux ???
be that as it may if that happens to be a desktop computer... is it a sata hard drive ??
Robert
Posted on Dec 16, 2008
My compaq presario c700 will not boot and it's saying that there is no bootable device, insert boot disk and press any key, however, i do not have a boot disk
Your Compaq did not detect the hard disk, that is why it is asking for a bootable device such as a boot floppy disk.
Check the BIOS configuration to see if the hard disk is detected, if not then re-seat the hard drive and boot up the Compaq again.
If it still does not boot up, then the hard disk is probably faulty.
To get the Compaq operating again, replace the faulty, install Windows operating system on the new hard drive, plus the Compaq's device drivers and your programs.
Jan 09, 2011 | Computers & Internet
Compaq C700 XP Downgrade HELP!!!
When you first start the computer, go to the BIOS (usually press [Delete]) and make sure the hard drive you are installing Windows XP to is the second or third boot device. If your CD drive is IDE and your hard drive is SATA you may have a problem in the BIOS of not being able to cross from IDE to SATA.
Jun 10, 2009 | HP Compaq Presario C700T
Hello... i have compaq c700 was corrupted and then i formated it but the display say there's no disk.. anybody know about this problem! please help! i can't install OS!
the reason you probably cant install is because your probably trying to install windows XP on a sata hard drive.. xp doesnt contain sata hard drive drivers.. u either have to use vista, find the sata controller drivera nd load from floppy by hitting F6 during setup.. or have someone slipstream the drivers into a copy of xp.. try emailing info@logiccomputerservcies.co.uk as I know they can help
Jun 08, 2009 | Compaq Presario 700 470024-192 Notebook
I had the same issue with sony vaio, try to download superdisc and the burn it to a bootable cd. Boot the system from the superdisc and then try to erase the MBR and then try to install, it should work.
May 30, 2009 | Compaq Presario C700T Notebook
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Jan 27, 2009 | Compaq Presario C700T Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Installing Windows Server 2003 on a preinstalled Vista OS
The reason it is showing "no hard disk" is because you have a SATA hard drive, and there is no SATA support on the WS2003 software, so it doesn't even "see" the drive when trying to install.
What you can do is download SATA drivers for your hard drive to your machine. Once downloaded and/or extracted, restart the installation but choose F6 to load "SCSI or 3rd party drivers", then point to the downloaded drivers.
Your installation will then load the SATA drivers, thereby recognizing the hard drive and you'll be able to successfully install Windows.
Hope this helps - remember to rate :)
Oct 06, 2008 | Microsoft Windows Server Standard 2003 for...
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Compaq Presario C700T Notebook Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
