Question about M-Audio Computers & Internet
Sound card problem
Please my sound is not functioning after a new XP installation, Coputer Component, Sound Card ( C-Media AC 97 Audio Device). How do I solve this permanently? Because I have tried all that I could but still to no avail
There is no audio divice for my hyunju sound drivers
Posted on Dec 16, 2008
Media player
open audio devices and sound properties in your device manager. Is your sound card listed? If so, highlite it and select properties...then see if it is enabled...if not, click enable this device. If not listed, try re-installing it with install new hardware. Finally, if its there, but wont enable, remove the device and reinstall it. If all the above fails, replace the sound card if its not intigrated. if it is intigrated, buy a PCI Plug and play sound card and install it in a pci slot.
Jul 14, 2010 | Microsoft Windows XP Professional for PC
No sound (AsRock P4 Combo)
1.
Check the speaker connections - take the plugs out and put them back.
Make sure the speakers get power.
Test the sound with headphones.
If it is a Laptop be sure the speakers are turned on (Usually an Fn function key).
2.
Load a system restore point from a date before the sound problem started.
3.
Has the audio service been started by Windows?
Click Start > Run > type services.msc - then click OK.
In the new window - Scroll down to "Windows Audio", right-click on it and select Properties.
Another new window - set the startup type to Automatic, click Apply and then click Start.
Have a look in "Play control" and any other sound mixer you may have installed to check if the sound is muted.
Go to Control Panel >> Sounds and Audio Devices.
Check to see if your sound card is listed.
If no audio device is detected proceed to step 5.
Be sure the Volume is turned up (at least half way).
The MUTE box should not be checked (go to the advanced window and make sure that nothing is muted).
Select the proper speaker settings under speaker settings advanced tab.
Set the speaker setup settings accordingly.
Is your sound card the default playback device?
Right click the speaker icon next to the clock >> Choose "Adjust Audio Properties".
Click on the Audio tab and select the correct device.
If you make any changes - click Apply, then OK before you close the window.
If you use another type of audio program, please refer to that program's trouble shooter for diagnostics.
Creative Sound Card owners can try this:
Click Start >> Programs >> Creative >> "Sound Card", for example Audigy >> Creative Restore Defaults.
4.
Check to see if the sound card is properly installed in the Device Manager.
Right click My Computer >> Properties >> Hardware Tab >> Device Manager >> in the "View" menu - click "Show hidden devices".
If there are yellow or red "marks" next to the audio, "Microsoft Universal Audio Architecture (UAA) Bus" or an unknown device - install drivers (see step 6).
If Windows does not detect an ONBOARD (Integrated) sound card >> Check to see if it is ENABLED in the BIOS (Setup).
If Windows does not detect a PCI sound card (an Added sound card) >> Shut the computer down, disconnect power. Take the sound card out and put it back again - if possible, use another PCI slot.
5.
Install available Windows updates, including DirectX.
Go to Start >> All Programs >> Windows Update.
6.
Installing drivers:
6a. Install the chipset driver first >> Reboot.
6b. If a "Microsoft Universal Audio Architecture (UAA) Bus" is present in Device manager >> install the driver >> Reboot.
6c. Uninstall old sound drivers:
Check in Add/Remove Programs in the Control Panel for an Audio device driver (i.e. AC97).
Go to the Device Manager and uninstall the driver (Right click on the device >> uninstall).
Install the sound driver >> Reboot.
The drivers to install can be found on a CD that came with the computer/motherboard/sound card.
Jan 12, 2010 | Asrock (P4COMBO) Motherboard
Replace faulty ac 97 with new sound blaster card.
hi, you need to go into your device manager and just disable the AC 97 sound card, them go to the control panel and get into sound options, and selectthe sound blaster as your default sound card o primary device .
Oct 07, 2009 | Microsoft Windows Xp Home Edition Sp2...
Install a new sound device
You probably need to install a device driver for your sound card if Windows does not support it by default. You should have a CD for the audio card which contains a driver, otherwise you can download it from the manufacturer's support site.
Here are some more steps on how to troubleshoot sound in XP.
Jules
May 15, 2009 | Echo Indigo Stereo Output Device for...
My c-media ac 97 or soundcard is not working
Your sound card should use the generic AC97 drivers, if not use the HD audio driver (generic or HD audio).
Post your results here, especially if these don't work for you.
Mar 23, 2009 | Computers & Internet
I format and installed xp on my laptop but no sound
Here is link to download your sound card driver.Download it and install.You will get your sound back
Creative Sound Blaster PCI 128 Sound Card
Thanks
Mar 12, 2009 | Compaq Creative Sound Blaster PCI 128...
RELOADED XP
yes, install new drivers, ****.
Feb 21, 2008 | E-Machines W3050 PC Desktop
Computers & Internet Logo
112 people viewed this question
Top M-Audio Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
bigdaddyd2
mark
mark
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
