Question about SanDisk Sansa e260 MP3 Player
Problem With Format
Hi ^^ I have a problem about my e260 player with formatting, because everytime i format my playing, it say " The device was unable to complete the format". Can someone help me fix it problem ? Thank You
    Brigadier General:
  • 6,966 Answers
Hi, you may want to try using the manufactures preferred method or better still update the firmware. It is available at http://www.sandisk.com/Retail/Default.aspx?CatID=1376. Please let me know if this woprks out ok with your Sansa e260. Regards
Posted on Apr 10, 2007
Videos list showing empty
You need to use the supplied Sansa Media Converter program to convert videos to a format the Sansa can handle. If you don't have the SMC, you may download it here.
May 13, 2009 | SanDisk Sansa e260 MP3 Player
Fromat sansa e260
To format your device..on your device..go under menu, setting and there should be a format option option there..and also you can format it using your windows media player..Open windows media player and make you sure you device is connected..And on the right side you should see your device listed...right click on the device and click format,.Note formatting will erase all data on your device
let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Aug 27, 2008 | SanDisk Sansa e260 MP3 Player
E260
I'd suggest formatting it and synching all the music back onto your mp3 player. Formatting it deletes all the music from it by the way.
To format:
1. Open up your Windows Media Player.
2. Right-click on the Sansa e260 in the menu on the left and click format.
There's also a more complex method, so if that method doesn't help just comment.
Aug 20, 2008 | SanDisk Sansa e260 MP3 Player
I don't have disk
OK, we need to know what kind of CD - is it the drivers or a music CD? If you wish to put videos on an mp3 media player with video capability, they will have to be in .mp4 format.
If you're trying to put music on a CD to be played on any device, it will have to be .cda format.
Jan 28, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 video question...
Im having this problem too. I believe the video needs to be formatted for the device. Problem is I dont know which forrmat the device supports.
Dec 06, 2007 | SanDisk Sansa e260 MP3 Player
My sansa e260 stopped working after unsuccessful formatting
I have guys, I just spoke with the Sansa representative. Even if you have Windows Vista, you do not need a drive for e260 given that Vista carries that drivers for it. If you have tried the steps above, but you Sansa still did not format successfully after using the recoverty tool. This is what you do:
Set you Sansa e260 in recovery mode
- set it to hold
- hold rec
- connect to computer while you are holding rec
- device should be now in recovrey mode
- go to my computer
- go to the folder 16B format
- you will see a text file
- don't worry about
- add a new folder and name Sansa.fmt
- wait up to 2 minutes
- message on your device should say formatting
- wait a few minutes for formatting to take place
- stop the device by removing it safely using windows Safely device removal tool on bottom right corner of your screen
- disconneting your Sansa and you should see a message upgrade finished, Sansa has been restored or something like that
- Power your Sansa on, and Bwala!!! your Sansa is back to normal.
Good luck
Dante
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
You can format the device in My Computer>Device Name (e260)>Right Click and select format.
If that does not work, change the mode on the device Settings>Mode or USB Mode and ty again.
Best of Luck.
Nov 07, 2007 | SanDisk Sansa e260 MP3 Player
Message states unable to format
Make sure you dont have Rhapsody, or Windows Media Player open. Go to My Computer>Device Name (e260)>Right Click and select FORMAT. If that doesnt work, change the mode on the device Settings>Mode or USB Mode and repeat. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e260 MP3 Player
Getting messgae Not enough space for MusicDB. Please free 6MB
If it wont connect to the PC, you need to put it into recovery mode and format it with the recovery tool from SanDisk. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e260 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
90 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
