Question about Toshiba Satellite A215-S5815 Notebook
Car plug in on 1997 intrepid
When i plug my car in shouldn't i hear something? A noise of some sort heating up the oil pan? Cause i hear nothing!
  • 247 Answers
No you ussually dont hear anything when you plug in your vehicle. you will know in the morning if it worked or not. block heaters don't make enough noise for you to hear.
Posted on Dec 16, 2008
I took my 1997 Mitsubishi eclipse to walmart and they couldnt change my oil because oil was all under the car.. where could my leak be coming from
An oil leak, could be drastic or small and could come from ANY part of the engine where oil flows. If you haven't had a low oil pressure light before, it might be safe to assume it's a slow leak. Depending on how many miles you have, the oil leak could be coming from the oil pan gasket seal, the head gaskets/valve cover seals, or maybe the oil filter itself! Sometimes a technician could not tighten it all the way and this could cause a mess. Even if you have oil "under" the car, which is normal for any old worn out car, it shouldn't be a reason to NOT have a oil change done. I would suggest doing it yourself or taking it somewhere else.
Get the car cleaned underneath (in an environmental safe and responsible manner) and try to check daily for oil sweating and where it could come from.
Also check some Eclipse owner's forums online to see if this is a common issue with your 1997 model. Good luck
May 27, 2012 | 1997 Mitsubishi Eclipse
Loud clacking sound on 2003 mazda 6. possible axle? happened after oil change. sounds like something is loose.
This noise can be caused by a defective outboard (wheel end) front axle constant velocity joint (known as a "CV" Joint). This would be louder on turns, more noticeable at lower speeds and sharp turns. Next it could be valve train noise, this would come from the top of the engine and this could be related to the oil change if a piece of dirt got into the oil supply to the hydraulic camshaft followers. At this point you need a professional to listen to the noise to determine the exact cause.
Dec 29, 2011 | 2003 Mazda Mazda6
My car either has a cracked block, needs head gasket or? When I put water in the radiator, it comes out the oil pan without starting the engine.
I think a cracked block would be very unlikely. More than likely to be a head gasket problem. A decent mechanic shouldn't have any trouble pressure testing each cylinder to diagnose the fault. I'm assuming it's a V8? there are other possible causes also. Cracked head, faulty inlet manifold (v8, if it has water jackets in the manifold). I would have it checked out before assuming it needs a motor.
Nov 06, 2011 | 1997 Ford Mustang Cobra
1997 dodge intrepid the oil light stays on been on for months no bad engine noises and the level is ok
You need to replace the oil pressure sending sensor but I'd have the actual oil pressure checked to be sure the oil pressure is'nt low as that could cause severe damage. I assume your oil level is correct and the oil isn't "foamy" or "milky" looking on the dipstick.
Mar 01, 2011 | 1997 Dodge Intrepid
My 97dodge intrepid is leaking oil and i want to know where is the oil pan?
Hi. You might need to Replace the oil pan gasket is the oil is leaking. Here's the procedure on how to Replace the oil pan gasket.
1. Jack up the front end of the car and slide a jack stand under the vehicle. Make sure the jack stand is securely in place, and then put blocks in front of the rear wheels to keep them from rolling.
2. Slide under the car and put a drain pan under the drain plug of the oil pan. Loosen the drain plug with a socket wrench and allow all of the old oil to drain into the pan. Remove the old oil filter.
3. Disconnect the negative battery cable and remove the dipstick and its housing. Remove the collar on the rear of the oil pan. If the vehicle is equipped with engine oil cooler lines that lead to the oil pan, remove them as well, along with transmission oil cooler clips.
4. Remove the bolts holding the oil pan, and carefully remove the oil pan. Remove the old gasket. Scrape it with a putty knife if necessary, but be very careful not to scratch the surface.
5. Wipe out the oil pan with a clean cloth or paper towel, and wipe the joining surface of the oil pan with cleaning fluid or solvent. Apply a thin bead of automotive sealer and install the new gasket.
6. Replace the oil pan, tightening the bolts securely. Replace the transmission oil cooler clips, engine oil cooler lines, oil pan collar, dipstick housing and dipstick, and reconnect the negative battery cable. Install a new oil filter.
7. Take the car off the jack stand and fill the engine with the appropriate amount of SAE 10W-30 or SAE 5W-30.
All the best!
Nov 09, 2010 | 1997 Dodge Intrepid
Knocking noise when i accelerate
Mar 01, 2010 | 1997 Honda Civic
I need to replace the oil pan on my 2002 Dodge Intrepid with a 3.5 Liter engine. What are the steps. Especially with the metal ubber pan gasket.
1.put car on a lift. 2.Drain oil. 3.make sure to have exact oil pan ready with seal in hand. 4.unscrew the bolts in a x fashon. 1-6 3-4 2-5 remove oil pan. 4.Clean all around where the oil pan used to be. 5.Attach new seal and oil pan. hand tighten all the bolts in a X fashon then tighten with a wrench or socket. 6.make sure oil drain plug is on good. 7. put new oil in typically 5 quarts. 8.put car on ground 9. All done.
Sep 02, 2009 | 2002 Dodge Intrepid
I have a 1997 dodge intrepid that i have been told the egr valve is my car hesitates, stalls or dies on me at random times. could this be the egr or something else?and also sometimes when it dies...
A bad EGR valve can definitely cause these symptoms, but would have nothing to do with the battery terminals. Unfortuneately, several other things can also cause these symptoms.
Jul 04, 2009 | 1997 Dodge Intrepid
Need specific location of oil drain plug to change oil
I have owned a 1999 intrepid for 9 years. And have changed the oil many times in the 170,000 miles I've owned it. This car comes mostly with a 2.7 liter motor. It does some times have a 3.5 liter. As you open the hood,there is a sticker that tells you what motor it has. If you have the 2.7, between the two front wheels you have a cast aluminum oil "pan" You will see a oil filter sitting vertical, towards the passenger side.The bottom of the filter is almost flush with the bottom of the oil pan. Just to the side of the filter,towards the driver side, is a hex head oil plug. It will take a 11/16" wrench to remove it.Hope this helps lbreen
Apr 22, 2009 | 1999 Dodge Intrepid
1997 dodge intrepid making noise
what area of the car does it come from? it could be any of the engine pulleys and hopefully not but could be the rods knocking inside the engine
Jun 21, 2008 | 1997 Dodge Intrepid
Toshiba Satellite A215-S5815 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
