Question about ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor
Replacing the inverter?
I have an Optiquest q9b-2. Brought it home from work and it was working earlier today...now I bring it home and no light comes on to show any power is reaching it, I have verified the power cord is good, hear a buzz coming from the upper right corner (with it upside down and cover removed and bottom towards me)
  • 4 Answers
The Optiquest Q9b has had a high failure rate due to bad capacitors on the power inverter board. Usually you can tell if the
capacitors are bad by looking at them to see if the top is bulging, if they are leaking, or if the bottom plug is pushed out. If you can use a soldering iron, you can replace the bad capacitors yourself. If you can't use a soldering iron, you can quickly learn enough to do the job by watching a few videos on You Tube. Here are a couple examples of videos on soldering and desoldering. Watch a few videos on both topics and you'll be good to go.
I found this extremely helpful tutorial on how to replace bad capacitors on the Q9b. It tells you how to disassemble the monitor, find the right circuit board to fix, and the tools and supplies you"ll need. However, the tutorial assumes, incorrectly, that there is just one version of the power inverter board. So don't just take for granted that you have to replace the same capacitors shown or that they'll be the same exact type the tutorial specifies.
The best thing to do is to read the numbers off any bad capacitors you find and buy new "radial-lead electrolytic capacitors" at Radio Shack ($1.49 each) with the same micro-Farad rating and the same or higher voltage rating (those are the two numbers you'll find on the capacitors). You can also buy capacitors online; just do a search.
Of course there are other things that can go wrong with a Q9b, but bad capacitors seem to be by far the most common problem.
I hope this helps.
Posted on May 17, 2009
  • 103 Answers
Do not order parts from viewsonic they are not good at getting out correct parts for their products. i am a tech and socialize with many that also have had dozens of problems.. watch out...
Posted on May 14, 2009
    Sergeant:
  • 226 Answers
If your inverter/power supply board has only one transformer, contact the resurrectek guy on eBay. He will repair your board for $24, per his advert. Mine has two transformers, and they are hard to come by. You can also search for the board number, and you will find the manufacturer has an office on Southern CA, with several supposed sites that sell their products.
tom
Posted on Jan 04, 2009
MANUAL
HERE YOU GO:
http://www.2shared.com/document/DvXLz7b2/q9b-3_ug_eng.html
Dec 17, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic optiquest flat panel lcd monitor power light flashes on and off with a popping niose
Look for bad caps with bulging/leaking tops as shown here:
http://s807.photobucket.com/albums/yy352/budm/OPTIQUEST/Optiquest%20Q9B/
Very common problem in all LCD monitors as you can see in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
How do I get the audio speakers to work?
Hello
-Make sure that you plug in the audio out from you computer to the audio port at the back part of you monitor -the audio controller of this monitor will be the function button in front.
the link below will contain the full manual of the monitor "http://www.viewsonic.com/products/archive/q9b.htm"
cheers.
Feb 24, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Optiquest q9b-2 blank white screen (lights up when powered up) no video ??no problem with computer, video fine on another monitor, tried this monitor on several computers same problem, blank white...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 06, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
LCD doesn't power up, light just blinks
Look at the power supply first; look for burnt parts, bad capacitors, etc.
Please post back what you find
Nov 27, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Momitor
Probable source of the problem is the horizontal output (and high voltage) circuit although it can be killing the video earlier than that too. First step would be to dis- and reconnect the video cable to ensure it isn't a simple contact problem.
Second, using the brightness and contrast controls to see if anything is still visible. If you have a single horizontal line across the screen, then the problem is in the vertical deflection circuit instead.
If you have nothing, turn the monitor off, wait a few seconds and then back on. If you get a picture first then only a dot, its back to the horizontal circuit again. Try to note how it dies.
You may be able to somewhat diagnose the problem this way but that is a long way from a repair and with the cost of labor and possible unavailability of some parts, you should get an estimate before repairing it since it is possible that replacing it is cheaper. This is not really a DIY project unless you have technical background and a couple of test instruments.
Nov 01, 2008 | Computers & Internet
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Not on
try eBay ressurectek for repairing you inverter/power supply board. If you have the one transformer (q9b-2) version, he says he can fix it.
tom
Sep 26, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor Logo
508 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
