Question about DEI Valet Keyless Entry System
Car starter not working
Own a 2005 Hyundai Santa Fe and it has a Valet remote starter/alarm installed. Starter recently stopped working... alarm and lock/unlock still work fine. The lights flash when using alarm but not when trying to start car?
  • 2 more comments
  • Anonymous Mar 13, 2014
    i tried the unlock lock and unlock thing still in valet mode?! can u help?
    DOORS WON'T LOCK OR UNLOCK WITH EITHER REMOTE. THE ALARM SYSTEM ACTIVATES AND DEACTIVATES. THE REMOTE START ALSO WORKS
  • Anonymous Mar 27, 2014
    No valet button, no remote, how can I turn alarm off?
  • Anonymous Mar 28, 2014
    There is no beep when locking or unlocking the doors. Car starts on its own at odd hours.
    Sergeant:
  • 233 Answers
Look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
Car starts by itself
Posted on May 19, 2009
Tip
What you need to know about Hyundai
I am a mechanic ..most people ask questions about these foreign hyundai motors ..below is an example of engines that basically if you ask about a Hyundai Xg 350 ,xg300 ..well allow me to hammer 90% of your questions in case you want to grab another motor ..these motors listed will work on 90% of all hyundai products ...Look at the starter sizes ,,all the same for the selected models ..then look at the motor sizes ..This will help you in solving some problems most do not give the specific questioning
100% NEW REPLACEMENT STARTER
FOR
STARTER
12 VOLT / CW ROTATION / 8 TOOTH DRIVE
REPLACES:
MANDO M62957
VALEO TM000A14401
BOSCH REMAN SR4118X
BOSCH NEWMAN SR4118N
HYUNDAI 36100-37210
FITS ON:
HYUNDAI
2001 SANTA FE 2.7L ENGINE
2002 SANTA FE 2.7L ENGINE
2003 SANTA FE 2.7L ENGINE
2004 SANTA FE 2.7L ENGINE
2005 SANTA FE 2.7L ENGINE
2006 SANTA FE 2.7L ENGINE
2003 SANTA FE 3.5L ENGINE
2004 SANTA FE 3.5L ENGINE
2005 SANTA FE 3.5L ENGINE
2006 SANTA FE 3.5L ENGINE
2002 SONATA 2.7L ENGINE
2003 SONATA 2.7L ENGINE
2004 SONATA 2.7L ENGINE
2005 SONATA 2.7L ENGINE
1999 SONATA 2.5L ENGINE
2000 SONATA 2.5L ENGINE
2001 SONATA 2.5L ENGINE
2003-2008 TIBURON 2.7L ENGINE
2005-2008 TUCSON 2.7L ENGINE
2001 XG300 3.0L ENGINE
2002 XG350 3.5L ENGINE
2003 XG350 3.5L ENGINE
2004 XG350 3.5L ENGINE
2005 XG350 3.5L ENGINE
KIA
2004 AMANTI 3.5L ENGINE
2005 AMANTI 3.5L ENGINE
2006 AMANTI 3.5L ENGINE
2001 MAGENTIS 2.5L ENGINE
2002-2006 MAGENTIS 2.7L ENGINE
2001 OPTIMA 2.5L ENGINE
2002 OPTIMA 2.7L ENGINE
2003 OPTIMA 2.7L ENGINE
2004 OPTIMA 2.7L ENGINE
2005 OPTIMA 2.7L ENGINE
2006 OPTIMA 2.7L ENGINE
2002-2005 SEDONA 3.5L ENGINE
2005 SPORTAGE 2.7L ENGINE
2006 SPORTAGE 2.7L ENGINE
2007 SPORTAGE 2.7L ENGINE
2008 SPORTAGE 2.7L ENGINE
on Oct 24, 2013 | Hyundai Cars & Trucks
Remote start locks doors but won't turn over engine, installed by dealer, two remotes do the same. Changed batteries in remote.where is the kill switch?
most remote starters have a valet feature to turn off the starter but allow locks/trunk to continue to work. all brands vary..
Jan 04, 2016 | 2013 Hyundai Santa Fe
What tools do I need to replace the starter on a 2006 Santa Fe Limited?
Made a video showing how I replaced the starter on my 2005 Hyundai Santa Fe. Should be the same.
May 08, 2015 | 2006 Hyundai Santa Fe
Where is the starter located on a 2006 hyundai santa fe
Made a video show how I replaced the starter on my 2005 Hyundai Santa Fe. Should be in the same place.
Jan 31, 2015 | 2006 Hyundai Santa Fe
Hyundai santa fe starter were is it located
On the 3 different engines (4 cyl & both V6s) on LH side (radiator side) below the exhaust manifold. All have two14mm bolts mounting them to the engine.
ILLUSTRATION:
Aug 27, 2011 | 2004 Hyundai Santa Fe
MY 2003 HYUNDAI SANTA FE WILL SOMETIMES NOT START. YOU TURN THE KEY AND NOTHING HAPPENS. FROM MY LIMITED EXPERIENCE IT SOUNDS LIKE A STARTER PROBLEM. BUT HOW CAN I MAKE SURE ITS THE STARTER AND NOT THE...
You could take the starter out and take it to a place like autozone and they can test it for free.They even test the system I believe when the car is still running.All stores have different testing equipment.
Mar 04, 2011 | 2003 Hyundai Santa Fe
I have a new prestige APS-57C remote starter installed in a 2009 Hyundai Santa Fe and I have a problem with the factory alarm going off every once and awhile. The majority of the time everything is fine,...
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Jan 25, 2011 | Prestige Remote Start
Where is the starter located on a 2006 santa fe..is it easy to get to?
You will be finding the starter motor at the mounting point of Engine & transmission case towards the bottom, above the crank case. you will able to access to this motor from bottom.
Jun 04, 2010 | 2001 Hyundai Santa Fe
DEI Valet Keyless Entry System Logo
1,710 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
