Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
USB port dislodged on 1TB Seagate, how do I open the case?
My 1TB Seagate was connected to a lap top and fell off a desk. The USB port broke and is loose in the box. The unit will obviously no longer power up. I am interested in extracting the HD so I can try it in a new case like this one:
The problem is I don't know how to remove the hard drive from it's current case. I see two screws, one inside the stand which is accessible through a grate and the other in a compromising position above the stand and below the case. Any help would be much appreciated!
  • 1 more comment
  • mouraalexand Dec 16, 2008
    God bless youtube.
  • tina_0091 Feb 20, 2009
    I have 1 TB seagate Freeagent external hard drive and 500GB of data inside it. I found it sudden broken and i want to recover my all data. I am planning to change the case. Can anyone tell me which kind of external case will work with Seagate Freeagent (2008) external storage?
    If anybody have other options to recover data then please let me know it.
  • Anonymous Feb 22, 2009
    The dog knocked the hard drive off a low-lying coffee table onto a thick carpeted floor. I was stunned that the hard drive no longer powers up nor is recognised by the computer. I see what might only be described as a 'keyway' for a special unlocking key, but do not wish to spend inordinate sums of scarce scratch for something I can repair myself. Nor do I wish to demolish the beautiful case in an ill-considered attempt to enter the case.
    A key seems the most logical way to fix this temporary problem. Where might I purchase one?
I did open a Seagate FreeAgent Pro 1TB !
The thing was awful, the case is just a nightmare to crack. The base is easy, you have the screws under the tiny rubber feet. The metal over the electric parts is easy to take apart, you just unglue and carefully open. You unscrew then the four flat-headed screws the hold in place the electrics, and the three big ones that hold together the base and the upper part.
Here comes the nasty part.
You unplug all connectors, but the upper case is VERY (I mean VERY) well tightened. It's held in place in 4 points, and the plastic made my fingers bleed. I can surely say it's a very well made case, strong as military, but impossible to open without destroying.
In the upper part the plastic holding points are quite close to the lower edge, but the two lower ones are somewhat 2,5 or 3 inches away from the edge, and this is where you'll get stuck. I couldn't just pry them open, so in the end, even though the unit is safe and sound, the lid (the part with the Seagate logo) was torn an bent.
My problem was at the electrical part, so I don't care much for the case, but I feel bad for having to literally destroy such a good-looking external enclosure.
Hope this is helpful to all of you in trouble with this issue !
Posted on Dec 29, 2008
  • flyirwin Dec 21, 2010
    I broke the usb port on my 1 tr sea-gate drive as well. took forever to figure out, but what i did was;
    - call sea-gate for permission to open the case to get to the drive. Otherwise it voids the warranty.
    - brought a 30 dollar universal drive adapter. (a cord that accesses various drives) mine was from newer technology, usb 2.0 universal drive adapter. i brought the 1st one i found.
    - got the information off with the cord. (my computer, laptop/desktop, didn't have a slot to get the information off the drive directly)
    -sent drive to sea-gate at the address they gave me, and got a new drive replacement.
    it works better and cheaper if you can install the drive into a desktop computer, but mine was to old. also buying a new case was like 60 way
The base cracks in two peces at the join. Then remove 5 screws. The upper case is tightly secured, but you'll see two slots in the thick edge where you can pry apart with a screwdriver.
Posted on Dec 28, 2008
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
then try again if problem not solved, mail me to
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
I have a Segate Free Agent Desk 1TB External HDD. Today when I plugged it in the power supply, the LED light keeps on blinking. The Drive is not getting detected by my Laptop. I tried it on my Desktop, But...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 30, 2010 | Seagate FreeAgent Pro 1TB External USB...
Can you charge a lap top thru usb port on a desk top
Hi guest, you cannot charge the laptop thru usb, it will be solely on the AC adaptor port. USB's are functioned for multi-media devices such as cameras, MP3 players, etc..
May 15, 2010 | Computers & Internet
I left my memory stick in my lap top. Dislodged
i guess you just broke the usb.. try to connect on other pcs if still works...hope this helps..
Sep 01, 2009 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
6,746 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
