Question about Apple iPod MA446LL/A MP3 Player
My ipod is plugged into the computer and itunes doesn't recognize it so i can sync it. But it is charging and it shows up in My computer. help me!
    Sergeant:
  • Apple Expert
  • 250 Answers
Normally this is down to old or faulty drivers on the pc. Have you tried reinstalling the latest version of iTunes from the Apple site? This will likely repair this if it is showing up in MyCmpouter but not in iTunes.
Posted on Dec 16, 2008
SOURCE: My Computer and iTunes does not recognize my iPod
my Ipod keeps beeping when plug in computer snd won't do anything else
Posted on May 15, 2008
Download the Ipod Reset Utility from apple.com
Posted on Jun 16, 2008
  • 4 Answers
SOURCE: ipod not recognized by computer or itunes
I had the same problem. The problem ended up being with Itunes not working right. The solution I found was to download the program winamp and download the plugin for apple ipod. Then you can sync and add software thru winamp. After syncing one time it even worked with itunes but I like winamp better, so I synch all music using winamp.
Posted on Oct 23, 2008
ipodslinger
  • 688 Answers
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
Posted on May 24, 2009
mneilsen2084
  • 342 Answers
SOURCE: itunes does not recognize the ipod when plugged in to computer
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
After you restore your iPod you should be able to sync the iPod just fine.
Posted on Jul 02, 2009
Ipod will not sync
You want to be sure that the computer is recognizing the iPod. Apart from iTunes, when you plug in the iPod to the USB port, it should show up in My Computer as a device. If it does not, try a different cable or different USB port on the computer. Until the iPod is "seen" in Windows, it will not be able to communicate with iTunes.
Hope this helps
Sep 23, 2013 | E-Machines Computers & Internet
How do i download songs to my iPod model no.A1204 EMC no. 2125? and how to charge it?
As with all iPods, you must use Apple's iTunes application to sync your music with your iPod Shuffle.
You'll need to install the latest iTunes by downloading it from Apple click here> and then installing it. You install iTunes like any other downloaded program by double-clicking on the resulting icon after iTunes has successfully downloaded.
Follow the on-screen directions to install iTunes.
Once iTunes is installed, start up iTunes and have it search your computer for music for it to manage for you. While that is going on, plug the white USB cable that came with your iPod into your iPod Shuffle and into one of the USB ports on your computer. This will trigger iTunes to recognize your iPod Shuffle and ask you whether you want to set it up with this computer.
Follow the on-screen prompts to sync your iPod Shuffle with your computer.
To charge your iPod Shuffle, just keep it plugged in to your computer using the supplied white USB cable. Keep the cable connected until the battery indicator on the ipod Shuffle shows that the battery is full.
Thanks for using FixYa and Happy New Year!
Jan 03, 2011 | Apple iPod shuffle MP3 Player
I plug my ipod into the usb plug in and it wont show up in itunes so i cannot update it or add new songs and playlist. it shows the charging symbol but will not show up in itunes
1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems. If you don't know how to do that, you may refer to this iPod tips
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
4. Download and install the latest version fo iTunes for a try.
5. You may try this iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
If you have any other questions, feel free to email me.
Jan 30, 2010 | Apple iPod nano
My computer will not recognize my Ipod when plugged into the USB
do you have itunes installed ? if not install itunes and if so try and see if it is recognized on another computer if it is seen by another computer try and uninstall the software on your system and update and reinstall it
Sep 24, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano 4G silver not syncing
Well if you bought it off of ebay or some other internet site you might have bought a clone ipod that only syncs with windows media player, but if you bought it from a certified Apple reseller than I dont think I know. goodluck !
Feb 28, 2009 | Apple iPod nano
install the version 7.7.20.14 it may work
Jan 09, 2009 | Apple iPod nano
thats happened to me before I made a new account on my i tunes and there is no sync on i tunes what ever song you want you click hold and drag to your music list
Sep 05, 2008 | Apple iPod touch
Try this: turn off your ipod, hold the home button, and plug it into itunes while still holding the home button until a picture of the itunes symbol appears with a cable under it. itunes should say "ipod found in restore mode". This will completely reset your ipod, hopefully fixing any bugs or problems in it. also, you will lose all data saved on the ipod that isn't also backed up by itunes. Music, pictures, and video can be re-synced.
Aug 16, 2008 | Apple iPod touch
Ipod not recognized by computer or itunes
try http://www.vaxtex.com - they may be able to help
Jul 09, 2008 | Apple iPod nano 3rd Generation
Apple iPod MA446LL/A MP3 Player Logo
19 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
