Question about Mercury P4VM800M7 Motherboard
My system date is automatically changes how to problem
  • 4 more comments
  • Anonymous Dec 18, 2008
    l;vdsfvgdvgdfvgd
  • jodhpur Feb 17, 2009
    My System changes to 01 jan 2090
  • farhan15_sep Mar 20, 2009
    my system date automatically changes to jan 2090
  • rajeswar Apr 20, 2009
    the date and time is chaning in two computers same and this problem came at same time and one error pop-up that 256.exe has encountered a problem need to close. it is not CMOS problem it is virus problem but even my symantec anti virus also can't fix this. pls help me
  • ktkb5575 May 09, 2009
    i hv x3400 IBM server and Date automatically change to Year 2000.. how to solve it??
  • Andrew
    Andrew May 11, 2010
    Does it keep changing to the same date?
    If so, what does it keep changing to?
The date is chaned to 01 jan 2090
Posted on Feb 17, 2009
    President:
  • 2,110 Answers
You have to replace ur CMOS battery on ur motherboard...
Posted on Dec 16, 2008
  • 28 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
109
Posted on Mar 07, 2009
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
Sep 29, 2018 | Time Computers & Internet
How do I change the time on Alcatel one touch FLIP PHONE
Let's try this:
Go to Settings:
  1. Scroll down to 'SYSTEM,' then tap Date & time.
  2. Select Automatic date & time.
  3. Turn Off.
  4. Clear the box next to Automatic time zone.
After that select "Set Time"
Mar 14, 2016 | Alcatel Cell Phones
How do reset the time
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Nov 01, 2015 | Pantech Cell Phones
How do i set the time on a pantech p5000?
Date and Time Settings - Pantech Marauder™ [Device-Specific Instructions]
  2. Select Settings.
    1. Select Set date.
    3. Select Set time.
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Change the time zone to CST - it is stuck on GMT
Go into your settings, system date & time. Ensure the Automatic date and time is checked, along with Automatic time zone.
You can also make adjustments to time and date formats.
Back out, and restart your tablet to see if this works.
Date\time is a software function. Check to make sure you have the latest software version uploaded.
Mar 03, 2015 | ZEEPAD 7 inch Android 2.2 Tablet
Huawei H881C
This is may be your c-mos battery life ends. you can change the c-mos battery (the battery that you see in the mother board same like watches battery) and check. the time and date automatically changed. it's coast is very cheap.. Try it and enjoy...
Nov 15, 2013 | Computers & Internet
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Dec 06, 2012 | Computers & Internet
HOW TO CHANGE DATE FOR 2010
on a PC, double click your Clock on the lower right hand side of the screen. adjust to the correct date. If this did not update automatically then you have issues with your operating system or system board.
Jan 03, 2010 | Symbol PDT 3100
Display problem
try to do a system restore, for windows (xp or vista) click start>all programs> accessories>system tools>system restore> next> choose date> next....>system will automatically restart and reset your computer back to the date you have chosen. Just make sure that you choose a date when all was working ok.
Feb 16, 2008 | Compaq Presario 1200 Notebook
AUTOMATIC CHANGES TO DATE
Check your bios and set the correct date there also. If this does not solve your problem check for a virus by running a scan with your antivirus program. If you do not have an AV Software Program check out this one which is very good
www.free.grisoft.com
Oct 16, 2007 | Microsoft Windows XP Professional for PC
Mercury P4VM800M7 Motherboard Logo
1,781 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
