Question about Lexmark X4530 InkJet Printer
Scanner won't work do to needing twain I have a Lexmark X3500-4500 series all in one. I have been troubleshooting all day, and I can't seem to find a solution. My imaging studio will not let me do anything with my images, if it loads at all, and my lexmark will not scan to my computer. I have a 64 bit Windows Vista Ultimate OS. I have downloaded the updated drivers, and still have the same problems. The Imaging Center keeps saying something about a JIT Debugger. I tried to do this and ended up having to restore my system. I hope someone can help!
  • 1 more comment
  • eben_ezer08 Dec 23, 2008
    I get can not download applications, thats on the printer. on the computer it says that i need to plug usb, unplug power on printer, restart computer.
  • b2746 Dec 23, 2008
    cannot retrieve application list
  • k1277 Jan 02, 2009
    I have the same problem. When I try to scan a picture it tells me to press the scan button on the front panel and then follow instructions. All I get is a screen on the printers panel that says it can not download aplication list. I am also running windows vista home premium x64 on an HP dv7 1130. It prints fine! ?????
    Befuddled
Andi2009,
Thank you as I followed your idea and it worked like a charm. thanks again! All with the same problem please do the same! It will work!
Posted on Jan 07, 2009
Hi peoples. I had the same problem not too long ago. in the end i uninstalled and re-intalled the printer on my PC (with Vista OS) and have not had any issues in scanning since. Hope it works for you guys too.
JUST TO PRINTER IN SCAN MODE, THEN IT WILL ASK YOU TO WHICH PC YOU WANT TO SCAN, SELECT IT, THEN PRESS THE CHECK MARK, IT WILL ASK YOU FOR A 4 DIGIT PIN THAT YOU PUT DURING INSTALL, THEN PRESS THE CHECK MARK AGAIN, IT WILL ASK YOU TO WHERE YOU WANT TO SCAN, EITHER MS WORD, PHOTOSHOP, ARCHIVE, EMAIL, SELECT THE WANT YOU WANT AND PRESS THE CHECK MARK AGAIN, AND WOILA!!!!
Posted on Apr 03, 2009
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
UNABLE TO OPEN TWAIN SOURCE
I a have many years reparing canon scanners so here is my suggestion for you.
You didnt specify what scanner you have but your problem is a common one. I would go to the website of the manufactuer of your scanner and download the latest drivers (try googling the make and model of your scanner and adding drivers on the end of it), which will include the twain drivers you need then I would try the scanner again. I think this will correct your problem.
I hope this helps you out.
Mar 05, 2011 | Office Equipment & Supplies
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
How does one scan a picture with an all in one Lexmark printer
Hi, normally, if you have installed the complete driver set of the all-in-one, the easiest way is to run a program with scanning capability i.e. photoshop, or word. the software normally given with a scanner is a 'twain' which becomes linked to the photoshop program. If you have MS word (I'll use this as an example ), ensure the scanner software is installed, the brother switched on and connected to the computer correctly click Insert select picture then scanner - (or it may say twain). At this point the Brother mini program - the 'twain' should start and then follow the scanner instructions and a scan of whAtever you have selected should be inserted into the word document. Bit of trivia - TWAIN stands for Tool With An Interesting Name - yup it really is!.
Apr 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
My Brother MFC-240C's scanner won't work.
Sir,
check this site for all troubleshooting tips for scanner. http://welcome.solutions.brother.com
Thanks Good Luck
Sep 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Cant get scanner to work
follow the link and it will show how to use the scanner.
http://support.lexmark.com/perl/support/support.cgi
Mark
Apr 29, 2009 | Lexmark X2600 InkJet Printer
Lexmark X4530 InkJet Printer Logo
608 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
