Question about Kenmore 62622 Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Microwave all of a sudden started making loud buzzing sound when turned on and no heat.
  • 2 more comments
  • sewershark Dec 17, 2007
    I have the similar probelm with the Model 721.80522. When I try to heat anything, the microwave activates, lights on and turntable moves. Then I hear a loud buzzing sound, like something inside is electrically arcing. I haven't tried running it empty, however.
  • bcrowley Dec 18, 2007
    very loud buzzing noise when turned on
    model: 61601 (hood combination)
    thanks for your help
  • Tazboy Jan 16, 2008
    I have the Kenmore model # 721.80523500 hood combination and it too started making a loud buzzing sound when turned on.  For a couple of days, it made the sound intermittently, but now, the buzzing sound is constant.  It doesn't heat any thing I put in there. The only time it sounds normal without the buzzing sound, is when I try to heat on Power=0.  But you can't heat anything with 0 power, and it makes the buzzing noise with Power = 10 thru 100.  Is this something I can repair myself?  Please help!
  • Anonymous Apr 30, 2009
    "Microwave makes loud buzzing sound when on and no heat"
  • Kenmore Master
  • 9,174 Answers
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Posted on Mar 21, 2007
  • Hays Clark Apr 06, 2012
    I have the same issue, when I put a cup of water in it and cooking on a low power level the buzzing stops and sounds normal. Any setting Power Setting higher then 1 will cause the buzzing to start again.
    I have the same isssue and tried the low power step. The buzzing goes away when on Power Level 1. Any power level above 1 the loud buzzing returns.
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Kenmore Over the Range Microwave making buzzing sound and not heating
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
Jul 18, 2012 | Microwave Ovens
My microwave no longer heats anything and also makes a really loud buzzing sound when i attempt to use it.
The problem is most likely caused by a defective magnetron that "heats the food" is loading down the high voltage transformer causing it to make a loud buzzing sound. The cost to repair (depending on make and model) will probably approach the cost of a new microwave oven when you factor parts and labor.
Jan 23, 2011 | Microwave Ovens
Microwave making loud noise behind control pad and won't heat
Sounds like the magnatron (the bit that creates microwaves) could be goosed. Remove outer cover ( Isolate from the electric supply then remove screws at bottom on the sides).
Find big lump that says on magnatron with model nos etc on, any good electrical supply shop ( Maplins etc) should stock new one.
It is easy to change. It took me about half an hour having never done one before.
Buyer beware the price of the parts could be in excess of a new microwave.
Shop around
Sep 15, 2009 | Panasonic NN-T993SF Microwave Oven
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Kenmore 62622 Microwave Oven Logo
1,999 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
