Question about E-Machines eMachines Desktop PC
Hi, How can I make my eMachines EL1210-01e desktop wireless, is it possible? Should I get an internal wirelss card? I have cox cable, router and everyting/ thank you, epdoss
  • 8,197 Answers
Just get the wireless internal card
Posted on Dec 16, 2008
    Scholar:
  • 40 Answers
While an internal wireless card would be the most straight forward, there is also the dongle to consider: a usb device which acts as a wireless card. I have two or three myself. While my particular dongles use a proprietary software driver (not always a bad thing), there are more mainstream ones which are cheaper than internal wireless cards, easier to install (you plug it in the back of your computer into a USB port and it works, no fuss), very portable, and typically unless you go with a strange brand, they are reliable and simplistic enough to use.
I do not endorse, work for, or get paid by Newegg in anyway, shape or form, etc etc. However, the following link should give you a good idea on Wifi Dongles. Check Here.
If you expect to connect from a distance (say, beyond 30 feet indoors with walls inbetween) you may wish to get a model which has a stick-out antenna, of which there are several. Some dongles should work with the wireless networking provided in Windows while others use their own software drivers. Personally I find Windows to be a pain to configure and keep stable, so a third party driver for the dongle is not a bad thing necessarily.
While shopping, be sure to read the specifications. Getting a dongle which supports encryption such as WPA and WEP, as well as can use 802.11b/g/n, different Wifi channels, etc is important as you never know what you will want or need to connect to. If you change computers you wouldn't have to worry about whether or not the card is compatible so long as the OS is completable.
Specifically dongles like the Rosewill RNX-N100 and RNX-G1W provide a wide range of capabilities if you need them, are cheap, quick and easy. I do not endorse Rosewill directly, but I have experience with Rosewill. Both models work with XP and Vista 32/64bit, as well as Mac OS 10 and above for the N100.
These are merely options that I can propose. Shop around for different brands if you can, or go to a local PC hardware store and pick a wifi dongle out. Remember that if it doesn't work, you should be able to return it. Newegg offers 30 day return for refund and 1 year for replacement on many items. Your local shops may also accept returns. Depending on the brand and model, it may come with a manufacturer's warranty.
Hope this helps and please rate.
- Dshack
What cords are needed to connect my emachines windows 7 desktop computer?
  1. CPU Power Cord
  2. Monitor Power Cord
  3. Monitor video cable
  4. Mouse w/cable (unless wireless)
  5. Keyboard with cable (unless wireless)
  6. Network cable with 8P8C connectors (unless wireless)
  7. Speaker audio cable (unless internal or no speakers)
  8. Speaker power cable (unless CPU powered or no speakers)
Oct 22, 2015 | eMachines Computers & Internet
Is it possible to make my W3506 Desktop Emachine wireless?
If by wireless you mean you are looking to be able to connect to a wireless router, then yes, it is simple. You can either install a wireless card inside the computer, if you have an empty slot available, or you can get an external wireless card, which plugs into an open USB port, the easiest way to go. Best place I know to find these is at www.newegg.com, or try Amazon.
Aug 01, 2013 | E-Machines eMachines Desktop PC
Do I need a USB adapter to connect to a wireless network?
You need a wireless card. It could internal or external as a USB device.
May 20, 2013 | eMachines T5048 PC Desktop
How to set up a internent connection for 2 companies both with independent lines using a single broadband connections and DrayTek V2930VN Wirelss Router/Firewall with VoIP.
The easiest solution is to use a simple router (wired-only) to connect to your Internet Service Provider.
Run a cable from one of the LAN ports on the router to a wired/wireless router, to provide access for the first company's computers.
Run another cable from another of the LAN ports on the router to a wired/wireless router, to provide access for the second company's computers.
May 05, 2011 | Draytek Vigor 2930Vn Wireless N Router...
Slow Internet Connect
i have the same router. I recommend that you download a new driver of your lan card for your desktop pc, also if you have P2P and bittorrent applications, try to disable them first and see the difference, those programs slow down the your internet, because they hog your bandwidth and connects to multiple users.
Feb 01, 2009 | Compaq Armada M700 Notebook
E-machine Lynksys wireless card
Yes it should but you need to have a wireless rougher also to pick up the modem
Dec 16, 2008 | E-Machines eMachines Desktop PC
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Fast Flashing Light - no Internet connection
Well, i also had a wrt54g router.Generally that type of router is only for a networkwith one, two max wireless items. When the led light is flashing very fast, it means it is working very hard. You may need to get a stronger router such as the wrt300n which can handle up to about 10 items. By the way, netgear routers are generally stronger and longer lasting than linksys.
Feb 07, 2008 | Linksys WRT54G3G Wireless Router...
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
262 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
