Question about Navman GPS
Fit Antenna to GPS - Navman GPS
  • hebu4445 Dec 16, 2008
    Have send clarification!
  • 6,487 Answers
Can you please inform us the complete detail of your problem , just post back here on this thread so we can all read your response....
Posted on Dec 28, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Http://www8.garmin.com/manuals/nuvi750-GPS-Atl_OwnersManual.pdf
just click this link and check out the option in in the trouble shoot column and much more help givr\en in details.
Posted on Dec 16, 2008
  • 13,433 Answers
Please clairfi your problem and also includ the model of your gps and details about the antenna you want to fit.
  • Ekse Dec 16, 2008
    Please send us the clarification on this page.
Garmin nuvi will not acqire satellites
Please indicate what Nuvi model you have. Some Nuvi models have an external antenna port while others do not.
Feb 12, 2015 | Garmin GPS
Gps antenee not recieving signals
please do check the terminal connector of the gps to the antenna
connector cable there should be is a voltage reading of 5 volt dc on the gps using a multitester.if the answer is no then your gps receiver
is out of order.if 4 volt to almost 5volt that should be
be ok..next step is to check the gps antenna cable connector
to the gps antenna using multitester a for short or open connection.set the tester to x1 and calibrate setting then test
short cable should reading full almost zero on the scale,open has almost
no resistance at all.a good gps antenna will read a difference
of forward and reverse resistance reading i cannot tell u the actual reading
of the antenna because it all depend on the length of the cable
and the gps antenna model.but it usually work if u test it this way
please do take note that u are very sure of your setting on the
gps it self before u make this test.
good luck
Oct 04, 2012 | Furuno GP1650DF GPS Receiver
Portable Garmin GPS for car
Most problems for this happening stem from the unit being mounted on the windscreen when the windscreen has heating elements in it, this causes the signal from the satellites from reaching the gps unit. If this is the case, the only option is to fit an external antenna through the sunroof onto the roof.
Jul 30, 2010 | Garmin North America GPS Map Update Maps...
My antenna no longer seems to work, is it an easy fix?
The antenna connection on the Quest is very fragile and is easily broken internally. Fit an external antenna and this should fix your problem.
Jun 16, 2010 | Garmin Quest GPS Receiver
I HAVE A F900BT WILL IT FIT IN MY 2010 CHEVY TRAVERSE? AND IS IT ALL PLUG & PLAY
It will fit, but the parts are expensive and it is not plug and play.
Parts needed:
Dash kit- Metra 99-3305 About $15-$20
Antenna adapter- Metra 40-CR10 (Chrysler antenna adapter) Yes GM uses Chrysler parts. About $10-$15
Wire harness/Interface- GMOS-LAN-01 (non bose or onstar) About $100
GMOS-LAN-02 (bose/onstar) About $120
The reason for the pricey harness is to retain data features on the vehicle and to interface with Onstar (GMOS02).
This is the right way so don't cut corners because it can cause issues on your brand new vehicle.
All of your safety chimes run through the stereo and not using the correct interface can cause issues with your gauges
www.metraonline.com or www.scosche.com are good sources for install parts info
May 14, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
Installing a new stereo in my Tundra
put ther gps under the dash, high as it is posible
Jan 05, 2010 | Clarion Car Audio & Video
I work in the GPS industry and I am looking for a way to transmit a gps signal from a basement of a concrete building. A little background, I work for a company that monitors *** offenders. I work in a...
I don't think that would be legal unless something is type accepted by the FCC for the satellite frequencies that are involved. It probably wouldn't be a good idea if the public were to start "repeater" transmissions on the GPS satellite bands. They do that in Cellular ... and they even often have problems there with "repeater"s going into oscillation between the outside and inside antenna if installed incorrectly - which tears up cellular companies towers.
If there isn't anything made legally to do this, and you were to make something without FCC acceptance, then you'd become the offender and could end up wearing the same gps bracelet you're working on.
If ... the gps devices would take an external antenna, then you could run an outside antenna and jack that in for testing and activation.
Nov 15, 2009 | Enfora Spider B3 Booster with GPS...
Raynav 300 the gps is not working
The GPS antenna with the 300 is not a GPS receiver unit like all the later Raymarine units and is no longer made. However the unit will accept input from a GPS receiver with Seatalk output. So you could use a 112, 120 or 125 receiver.
May 02, 2009 | Raymarine Raynav 300 GPS Receiver
Emerson NV 5000
It is called a transponder and I have one if you would like to buy it. defcend@hotmail.com
Jul 11, 2008 | Emerson NV-5000 GPS Receiver
GPS Logo
24 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
