Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Tecumseh 9hp craftsman snowblower will not stay running
If i keep spraying gas in the carb it will run but as soon as i stop it will not stay running,have new plug,clean fuel,gas getting to float,good spark ,THANKS TONY
  • 3 more comments
  • sandrozz34 Dec 20, 2008
    My tecumseh is doing the same thing. I got new fuel ,spark plug,carburetor cleaner. It runs for a few seconds after prime it and shuts down. If you resolve your problem,let me know how you fixed it. sandrozz34@yahoo.com
  • user60239825 Dec 24, 2008
    I have the same problem, it starts up and after a few seconds it start stuttering
    and eventually stops running. The exhaust seems fat as well. I believe it is just
    some adjustment on the carb, but I hav not figured it out yet.
  • s10man826 Jan 13, 2009
    In regards to your solution on the snowblower not running, does the Craftsman model # 536-88521 have a air breather. If so, where can it be found.
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    does it have an electric plunger on the carb? there would be a black or red wire connecting to the bottom of the carb
  • Al Perry May 11, 2010
    How long has it been since the machine was used?
    Scholar:
  • 76 Answers
First take the carb off of the engine and then remove the bowl, carefully take the float off paying special attention to the needle and how it is attached to the float. Next, lightly blow air into the fuel inlet while holding your finger over the spot where the needle goes in. Use a bread tie with the paper scraped off. Stick the wire through the pick up tube at the bottom of the carb. Find any other holes and probe those holes with the wire. Then thoroughly wash the entire carb with carb cleaner then blow the whole carb off. Then put the float and needle back in making sure that when putting the bowl back on that it seats tightly all the way around the rubber gasket. Also, just before you put the bowl on turn the carb upside down to see if the float is sitting level. If it is put the bowl on, If not then the spot where the needle sits on the float has to be bent one way or the other just a little until the float sits level. After the bowl is put in place, the nut that holds the bowl on the threaded area should have two possibly three holes plus the hole down the center, probe all holes with the wire. put everything back on the motor and try again. If it still won't run then you will need a carb kit.
Posted on Dec 27, 2008
Ran perfect last yr , gas was stale drained carb bowl and replaced gas it started up right away then cuople mins later it started blowing oil out of the oil over flow tube
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
Jan 22, 2014 | Tecumseh Snowblower Snow Blower Starter...
Craftsman snowblower will not start
Dump out the old gas and put in new.Try a spray of starting fluid into the carb. If it will not fire on the starting fluid there is somthing wrong in the ignition system. Pull out the spark plug and clean it with a wire brush. If it still won't fire the points and condensor need to be replaced.
Dec 21, 2013 | Craftsman Tecumseh Snowblower 7hp...
Tecumseh engine snowblower, will only run if I keep pushing the primer bulb, Why?
Take off the screw that holds the carburetor bowl on and clean the holes with a needle and blow air through them. These holes feed gas from thr bowl into the carb and may be clogged.
Feb 23, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Engine will not run/tecumseh enginelstall once it starts/hsk model
I assume this is on a snowblower?
Be sure you have fresh fuel.
You can also remove the bowl on the carb and spray carb cleaner in any orfice you see.
Always store a snowblower with fuel stabilizer in it. Otherwise it the fuel can "varnish" the inside of the carb and cause problem.
If it still doesn't start check compression.
Jan 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
I can't find my manual for a Tecumsah LawnBoy 824E 8.0HP Electric start snowblower. It starts fine, but does not continue running. I just filled the tank with new gas. It ran to run about 25 feet and then...
Hi
Sounds like a clogged carb which is a common problem for snowblowers due to they set around more then they get used and gas turns stale and clogs carb. Most of the times the problem is in the bolt that holds the carb bowl on it should have 2 or 3 small holes in it. Check that the holes are all open and clean if this does not help you will need to remove and clean whole carb.
Sam
Please vote
Jan 07, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Craftsman 9hp 29inch blade snowblower that is basically brand new. It had sat for too long and the gas turned to varnish. I had to replace the fuel line and i rebuilt the carb and it still won't...
Hi timmmarquez, I have the same snowblower. That plug is for a light if you want to install one. Can you smell gas when you try to start it ? If you have spark you can iliminate the kill switch. Make sure you have a clean spark plug to (not a weak spark). Good Luck.
Dec 24, 2009 | Bell Sport & Outdoor - Others
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Mower will not stay running unless primer button continuouly pushed. Gas seems to not be independently flowing, requires manual priming to stay running. As soon as primer gas used, will stop running.
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Apr 12, 2009 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
1,482 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
