Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker II microwave. sensor error lite comes on
Microwave runs for 2-3 seconds, then stops. manufactured in 2002
  • William Miller
    William Miller May 11, 2010
    On GE models, "SENSOR ERROR" appears on the display when:
    • Using
      the sensor feature, the door was opened before steam could be detected.
      Do not open the door until stream is sensed and time is shown counting
      down on the display.
    • Steam was not detected in the maximum amount of time. Use
      Time Cook to heat for more time.
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for maybe an hour. Then let us know if the hard
    reset does not fix it.
    It may have a bad sensor.
    How old is it and what is the model number?
    Scholar:
  • 111 Answers
Sounds to me like you have a bad magnetron tube. Call GE Factory Service as there is either a 5 or 10 year parts warranty. Or schedule a service call online at www.geappliances.com
Posted on Dec 20, 2008
Ge spacemaker II microwave started humming and nothing showing on monitor
My parents have had a couple of the spacemaker microwaves mounted over the range with the built-in vent. Over time, the seal on the control board gets a crack in it and the steam from cooking below it gets up into the control board and does it in.
Even if yours isn't mounted over the range, it sounds like a main control board failure.
Sep 10, 2016 | GE PEM31DMBB Black Profile Spacemaker II...
JEM 31 is not heating
Sounds like you have a bad transformer. Magnatron should check less than 1 ohm (with wires unplugged). Diode should check resistance one way and open the other. Must have a proper diode checker for this. Check resistance on the capacitor (make sure it is discharged first). Resistance should come up then back to open, reverse and same thing if cap. is good. Check resistance on transformer windings.
Nov 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a lound noise and no longer heats
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
My Microwave keeps beeping loudly and giving me a sensor error! I can stop it, but it starts again shortly after!
1.tighten nut at sensor socket 2.check connections to socket 3.does error go away when sensor is used,if so probably bad socket,replace
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker II
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Otherwise, yes, it may have a bad humidity sensor (gas sensor, as it's called) which needs to be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You should enter your model number as JEM31GA02.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or elsewhere inside, which is very helpful when troubleshooting, testing, and locating components.
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
323 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
