Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
My isignia blue tooth headset wont recognize on my computor
I go into add device, I put it in recognize mode.. but nothing.. plz help me..
Tengoinstaladoelsoft p no se con ectan los audifonos a lapto
Posted on Dec 19, 2008
I want to listen to music on my phone with my bluetooth headset
iIn order to listen to music on your blue tooth headset you first must pair them to your phone,To do this you first must turn the power to blue tooth to on in your phone menu,then you will have to put your blue tooth device into discovery mode,most bt manufactures use the power button for this feature,when turning your headset on continue holding down the power button for 6 to 10 seconds and a light should stay on ,thus putting your bt device into discovery mode thenfrom your phone you can search or add new device,it should recognize the device and ask for a pin or pairing code.Most manufactures use a factory 4 digit pin pairing code,they are as follows 0000,1234,9999,or 1111,once your code is entered they should pair,then you will be able to use your blue tooth device to listen to music.glad to be of assistance
Feb 26, 2011 | Radio Communications
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
Feb 26, 2011 | Motorola Mobility Motopure H12 Bluetooth...
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
I am trying to pair the jwin JB-TH130 with a MyTouch 4G cell phone and the phone will not recognize the bluetooth device.
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
Feb 19, 2011 | Jwin JBTH130 Bluetooth Headset
My iphone 4 cannot discover my BlueAnt Z9i. I put the headset right on tp of the phone and it just says "seaching". The headset is on and phone's bluetooth is on as well
First you must turn your power to the blue tooth to on in the phone menu,then you have to put your blue tooth device in discovery mode,most blue tooth device manufactures use the power button,by holding it down for 6 to 10 seconds when turning on the device it should have a solid light the you can add or search for device ,they will pair if you have your power on and your device in discovery mode once they pair you will have to enter a pin or pairing code.Most blue tooth device manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Blueant Z9i Bluetooth Headset
IT WON'T PAIR UP WITH MY CELL PHONE
To pair a blue tooth device to a cell phone you first have to put the blue tooth power in the phone menu to on,then you must put the blue tooth device to discovery mode,to do this you hold down the power button while turning your blue tooth device on for6 to 10 seconds,there should be a silod light on the device,then in your phone menu you can add or search new device they should pair if everything is right,then it will ask for a pin pairing code .Most manufactures use a 4 digit factory code they are as follows 0000,1234,1111 or 9999,once your code is entered it will connect to the device,i hope this helps
Feb 18, 2011 | Southern Telecom Emerson Bluetooth Headset...
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
101 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
