Question about HP Color LaserJet 3500 Printer
Hp Color LaserJet 3500 Paper Jam
My printer is jammed and it is saying its from Tray 2 but i know it's not. We have had this problem before and it was small pieces of paper jammed throughout the machine that had torm off. How do I find these small pieces of paper???? Thank you!
  • 5 more comments
  • Anonymous Feb 11, 2008
    I removed a small paper but it still says clear paper path. Where else am I to Look?
  • ectfana Apr 17, 2008
    I tried to check out your diagram but the link is broken. I can't find any small pieces of paper, but my printer still thinks it's jammed. Help!
  • Anonymous Jun 10, 2008
  • andys38 Dec 08, 2008
    I have the same problem, and this printer is really clean. The help guides you through removing the yellow and magenta (bottom two) toners, and turning a green thumb wheel to drive out a jammed sheet. Nothing in there.
    There seems to be wear on the picks for the tray 2, but the paper isn't even getting picked as if it's trying to feed.
  • Anonymous Dec 22, 2008
    PAPER JAM,13.20.00 ERROR OBSERVATION.
  • Anonymous Mar 24, 2014
    There is a paper jam in my tray 2 and it says to check the paper guides and make sure there is not a jam. There is no jam and we have turned on and off the machine.
  • Anonymous Mar 28, 2014
    printer sucked in about 25 pieces of paper can,t get out
  • 624 Answers
The only way to find paper remnants is to unplug the printer and inspect the paper path. It also helps to have a good focusing flashlight, skinny needle nose pliers, a can of compressed air (used sparingly) and a long thin probe. Your specific printer should be giving you jam messages with a location code as well. I?ve attached a link to an HP page containing a diagram of the 3500 paper path and the error code jam locations: http://h41206.www4.hp.com/webapps/IV3/node.iv?locale=en_us&prodSeriesId=315862&node=prodITRC%2FNL_HW_IPG_plakCLJ3500_EN_01_E%2FN1%7C6%7C9&prodTypeId=18972&serverId=1#src I solved this problem in my shops years ago by not letting anyone else clear jams OR insisting that any paper removed as a result of a jam is given to me. If any corners or pieces are missing I know what to look for and approximately where. Good hunting and please don?t forget to rate this post.
Posted on Mar 21, 2007
My printer says paperjam - there are no documents. I have opened the back and looked for paper bits. Help
Maureen
Posted on Jan 19, 2009
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jul 23, 2009 | HP Color LaserJet 3500 Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
Jul 18, 2008 | HP Color LaserJet 3500 Printer
Paper jam
Here's a link to the service manual. Most of the issues with this printer can be done on your own once you have downloaded the manual. Parts are available at http://partsurfer.hp.com
Free PDF of Service Manual:
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%203500-3550-3700.pdf
Hope that helps you.
Jun 09, 2008 | HP Color LaserJet 3500 Printer
Says paper jam, no paper inside
If you are getting a paper jam error, but no paper inside- Check your Pick Up rollers in the paper tray and then check for any stuck flags in the printer.
Sep 20, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 3500 Printer Logo
1,279 people viewed this question
Clive
Clive
