When trying to load Roxio Creator 9, I get an error that states "Network error occurred D:CPdecoderPack_411/52069.msi" When I click OK the program continues to upload. However, I have problems when I copy one disk to another. It will do it once and then the optical drive will either lockup or not recognize another disc without a restart.
  • 611 Answers
It means some file is missing in the cd so pls try other one and network error means remove the cable then you try it in same cd after then try other one
Posted on Dec 16, 2008
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Feb 02, 2011 | Roxio Creator 2011
I am receiving error code 0643 when I try to install Roxio Creator 2010 Pro and then program uninstalls.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall your software.
Jun 11, 2010 | Roxio Easy Media Creator 10 Suite
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
After successful download of creator 2009, cannot open to homepag
mine did the same thing, i called dell , they could not fix 7 techs tried and failed. so i went to http://support.roxio.com and download creator 2009 service pack 4 (52.5mb) u have to register it first, then download . follow the instructions . mine works now.
Mar 29, 2009 | Roxio Creator 2009 for PC
Error Message:Sonic Cineplayer Decoder Pack E:\7da4c.msi
This whole error code is a pal around back scratch between Roxio and Windows. To get rid of the "error message" which they created, you have to pay $70.00 for their crapp- axx software that is not even very good in the first place, Too bad Apple is not such junk and expensive, or I would change over. Thanks for really sticking it to us Microsoft!!!
Dec 19, 2008 | Roxio Easy Media Creator 9 Suite (227100)...
Having installed Roxio Creator 10, I get a recurring message: "RoxMMTrayApp Module has encountered a problem and needs to close." Etc. It occurs even when I am not editing with that software. ...
ROXIO Multi Media Tray Application Module Has Encountered a problem and needs to close.
This Means ROXIO Creator 10 Try Application Encountered an error.
And since it happens while burning a disc
You should
1. Uninstall ROXIO Creator 10 , and reinstall it to make sure nothing is corupted.
2. If you still get the same problem it's time to check your intire system for errors.
This can mean you will need to take trouble shooting steps.
1. Use another burning program to see if you can burn without errors.
2. if you can burn fine with another burning program like NERO then chances are
you have an incompatability with ROXIO Creator 10 and should consult the documentation
to see if your drive is actually supported by it.
Do these things weed hopper and all will be well with you.
Az.
Sep 16, 2008 | Computers & Internet
Roxio Creator Basic V9 that comes included with HP Pavillion Desktop does not install
The latest is Easy Media Creator 10 Suite.
This Roxio Creator Basic V9 came with your Vista machine?
But you have to install it yourself?
Or did you have The V9 already from another, older HP machine?
If so it won't work on Vista.
Nov 19, 2007 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
