Question about Acer Aspire 4720 Notebook
Function Key Issue
Whenever I type a key that has a function command associated with it, the function key command is executed as if the "Fn" key was pressed down. When pressing the "Fn" key and then pressing the same key, it acts as if the "Fn" key is not pressed down. I've replaced the keyboard but to no avail. I have searched the Acer support site for a keyboard driver but could not find one, also I would use the recovery disks that I created when I bought the notebook but as I'm sure you've guessed, I have lost them:( Any advice or direction on what driver I need and where I can find it, or is a Motherboard problem? I'm positive that it has had no water damage so I am baffled at this one.... i have the aspire 4720z and all keys with a function command display the function option when the function key is not pressed down. how do i fix it?
    Scholar:
  • 46 Answers
I'm wondering if you have a function lock key. Try turning on numlock and scrolllock while typing. Either that or you could use system restore and possibly the integrated diagnostics of the laptop to see if the issue is hardware or software related (hardware would show up in diagnostics) for you to contact Acer. Usually one goes to them by pressing and holding the Fn key (ironically) and pressing the power button, or by selecting it from a boot menu (by pressing F2, F8, f12, or whatever key it is on boot up.
I would suggest for the mean time, just taking the key off and holding it down using tape. Or you could press the key a few times if it's causing trouble, or press and hold it (if that is what causes the Fn lock, I'm sure it exists for a 'good' purpose but have never actually used it). I might experiment with this one :P. Definately sounds absolutely not like water damage :P
Hope this helps, stay spicy and happy lappying :)
Posted on Dec 16, 2008
Dell inspiron n5030....touchpad not working..not showing in device man..have d/l drivers,incl synaptics.mouse device settings box emtpy.enable/disable greyed out.
Are you certain that the touchpad wasn't disabled accidentally from the Fn key? There are secondary features assigned to each of the Function (F1-F12) keys, usually in BLUE. On of them is to disable/enable the touchpad (toggle-type function, do it one time to disable, the next to enable). You press and hold the "Fn" key (next to the Windows key at bottom let of keyboard, then press the associated Function Key.
Dec 10, 2015 | Computers & Internet
My fn key is working backwards how to fix
You need to restart (to enter in BIOS) your computer to change this.
While first black screen comes Press F2 or del (this may differ in your laptop).
If you post exact type of laptop i can see what bios you have, but you can look for yourself for it.
If a bios screen (may be unknown to you) appear then find Function Key Behavior select Multimedia Key First or Function Key First.
Function Key First
This is the default option. Press any function key to perform the associated function. For multimedia action, press Fn + the required multimedia key.
Press any multimedia key to perform the associated multimedia action. For function, press Fn + the required function key.
Jan 18, 2015 | Computers & Internet
My keyboard has suddenly stoped working correctly, I think its due to me messing around with the Function Keys. Any ideas
I believe the num lock key is truned ON. IF yes, then whenever you type, it will give you only number. Try the steps below to unlockit:
Keep on holding the "Fn" Key and then press F11 (Numlk) key. i.e Fn+F11
It should take care of the issue.
Thanks and regards,
Jitha
Jan 27, 2011 | Acer Aspire 4720 Notebook
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
Hi fellas, i'm having trouble with my vaio pcg-k47. the fn key is on all the time, and instead of having letters on the key board, there are some that are wr5ting nnumbers. can u help me fix that? Can u...
Press the Function (Fn) key again to deactivate it.
Please check if the "NUM LOCK" is enabled. If it is enabled then press it to disable to resolve the letter/number key issue.
You may disable the Function key by removing the VAIO Event Services Utility or HKSERV Utility from the Startup.
1. Click on the Start, select RUN, in Run command type: msconfig and press the Enter key.
2. In the MS Configuration Utility, un-check the VAIO Event Services Utility or HKSERV Utility and then click on Apply then OK.
3. Then, restart the Computer. This will disable the Function key in the Computer.
Good Luck!!!!!!!!!
Nov 18, 2009 | Sony VAIO PCG-K47 Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Function Key Issue
Use air compressed can to clean under and around key (if issue could be mechanical)
Jan 12, 2009 | Dell Latitude CPX Notebook
Function Key Issue
Your keyboard may have a function key lock (could be up in the right corner) that locks the keys in the Fn mode. Look for that. I have seen this on several keyboards. On some keyboards I've been able to get around this by hitting the print screen, scroll lock, or pause key to unlock it.
Jul 04, 2008 | Acer Aspire 5002WLMi Notebook
Key board probs
Would these be keys that can also be used to enter numbers? do they have numbers on them as well as letters ?
If so I'm thinking that there is some sort of Num. Lock activated (perhaps via an FN key ?)
Can you tell us more about the laptop, make and model ?
Oct 18, 2007 | Computers & Internet
Acer Aspire 4720 Notebook Logo
420 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
