Question about Lexar Professional High-Speed 2GB Secure Digital Memory Card
Prevention tab Where is the info on which direction the prevention tab needs to be on my sdhc card? There is nothing in the package. Its a Platinum 2 sdhc 4gb card
    Brigadier General:
  • 3,006 Answers
The switch goes fully forward for unlocked and fully back (away from the contacts) to lock it.
Posted on Oct 06, 2010
Memory card maximum size
Your camera only can use SD cards. The SDHC is a newer generation of SD cards, that need a different protocol you access the files. The newest version is the SDXC version.
SD cards never exceed 4 Gbyte. The SDHC never are bigger than 32 GD and the SDXC are over 32 GByte.
When you try to buy a SD card, the biggest you will find will be 2 GByte. I own 2 SD cards that have 4 GByte, but even I can't find them on the net any more.
The cards are from Platinum. But I even can't guaranty you the 4Gbyte will work in your camera.
Some firms used to bring out new firmware, as soon as the SDHC cards came out. I succeeded to update my TomTom to SDHC and the old thing now even accepts 16 GByte cards. But Canon did not offer an upgrade for the V550, so you stay stuck to the normal SD cards.
Dec 30, 2013 | Canon PowerShot A550 Digital Camera
What SDHC chips are compatible with the BOSS BV8212T
The unit works with SD cards, not with SDHC cards. A microSD card in an adapter behaves like a SD card, while a microSDHC card in an adapter behaves like a SDHC card. There are electronic differences between SD and SDHC that prevent devices from working with SDHC unless they've been designed to.
You're limited to SD and microSD cards 2GB and smaller.
Mar 13, 2012 | BOSS AUDIO SYSTEMS BV8212T Car Video...
When i insert memory card in my camcoder aiptek dzo-v50s,i have got problem.card protect
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 24, 2011 | Cameras
Please describe your why do i get an error when i try using the sd card in my gatewayDCT20 camera
Usually when you see errors with the card it will be due to a few things. The card is bad or corrupt, the card is the wrong type, or the camera has a fault.
Usually the problem is the card (9 out of 10 times). The cards may need to be formated before use or if they go bad to correct them. If the camera won;t give you the option then try doing this on a laptop or using a card reader and try again. Usually card errors are from bad shut downs or running out of power while taking pictures. Sometimes the card is is dead and won't be fixed by reformatting so you can only replace it. (Don;t toss it as it might work in a laptop).
If the card is too big or the wrong speed some cameras will give an error. Not much you can do about this other than getting a new card. Nothing wrong with the card its just not compatible.
If you have this problem with several cards then the camera itself may be at fault. Unfortunetly that usually means repairing the camera or replacing it. Replacement is usually cheaper.
Jan 20, 2011 | Cameras
Can you get a hand manual for a L22 coolpix? with 9.67 Mb( 148 page download !! )this camera is worth nothing to me. Why is there no SD (2 GB) card in new package? Have not got one good picture yet!
You can order the manual from
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.215420500
There's no SD card in the package because Nikon doesn't know whether you want to use an SD card or an SDHC card, or what brand, or what speed.
Dec 03, 2010 | Nikon Coolpix L22BLUE Digital Camera
Just baught pny-4gb sdhc card, asks to format-no luck
You may have the card locked so that the format isn't taking. Verify that there isn't something that is physically preventing the format. If the slide is in the locked position move it to the opposite side.
Oct 24, 2009 | PNY 2GB microSD Memory Card
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
CANON DIGITAL IXUS 40 CAMERA
Most likely it is not compatable. The SDHC cards are a very different animal to the regular type of cards (which most cards up to 2 GB are). I wouldn't open the package until you are absolutely sure. All info I've found on your camera indicates up to 2 GB (non SDHC only) maximum.
Oct 21, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Lexar Professional High-Speed 2GB Secure Digital Memory Card Logo
Top Lexar Electronics - Others Experts
Lawrence Oravetz
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
