Question about Hannspree HANNS-G 19" Widescreen Monitor
Monitor doesn't turn on anymore.
I came to turn my pc on today and my monitor is just 'off'. It has a repeated clicking noise coming out of one s peaker. The power button doesn't work, it doesnt come up as green or orange. I have tried disconnecting it from my pc, running it with my pc, running it in any way just gives me the same result. The monitor is only 2 months old so this is extremely annoying-not least considering the time of year and the fact I cant afford to repair or replace it.
  • 2 more comments
  • the_final_cu Dec 16, 2008
    It's just the monitor, as I say I have tried starting it not even connected to the cpu and the problem is exactly the same.
  • ingolord Dec 26, 2008
    well, i have the same monitor and the same problem. the cpu can't be the reason, i connected it with my xbox 360 and you also can hear the sound when there is no vga cable connected
  • gina4xoxoxo Jan 02, 2009
    same problem. black screen. clicking noise coming from monitor front and flashing green light every five seconds as it makes the clicking noise.
  • Anonymous Jan 27, 2009
    Unfortunately, this is a common problem with Haanspree monitors. They use cheap capicators on the internal power adapter, which go bad, and causes this power 'cycling' issue. I had one, took it in for fixing under haans warranty, and it worked...for about 2 weeks before it started doing the same thing (this was actually for a client of mine). I also had a viewsonic monitor that did the same thing, I opeend it up and the caps were bad, it also had a "HaansStar" logo printed inside too (HaansStar is one of HaansSpree/Haans*G sub divisions)
    if you can get some replacement caps and have some soldering skills you might be able to fix it :)
    Guru:
  • 829 Answers
I think this should be a problem with the CPU and not the monitor, Is there a continuous beep sound coming , If so then there is a problem with the Memory.
Posted on Dec 16, 2008
My monitor ia not coming on. How can I get the monitor to work?
How long does it take to shut down? Common causes:
1 You may have an external monitor selected. Hold the function key (might labeled Fn, it's usually near the left shift key) and press F8. If the screen doesn't come back press it again 'cause there are three options (panel, external and both)
2 The screen might be dead. Plug an external monitor in and see if you get a picture. If so repeat step one and check your video settings.
3 The laptop MB might be faulty. No real way for you to test this.
Aug 28, 2012 | Acer Aspire 5100 Notebook
I have the VGC-VA10G, and one morning I turned it on and the monitor wouldn't turn on? The pc runs perfectly fine. It's just, everytime I try to turn the monitor on, it makes 2 clicking noises and doesn't...
check ur memory card remove the memory card and restart ur computer with out the memory id u hear beeps clean the contacts with an erasor and wipe it clean with a clean cloth and insert it int the slot after shutting down the computer
Oct 17, 2010 | Sony VAIO VGC-VA10G (027242685789) PC...
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    Clicking noises coming from monitor with hdmi cable attached to computer have no problems with other connections that came with monitor
    Try getting a video card, if not look for a new monitor.
    Reason i say get a video card your motherboard is probably working to hard depending on how old your pc is. When getting the video card it takes stress off the board when monitor is plugged into video card.
    Apr 21, 2009 | Computers & Internet
    U heare a noise and the moniter wort turn on
    Please confirm if the noise is coming from the monitor of from the desktop. If the buzzing noise is coming from the monitor - i suggest to request for a replacement. If not it could be a noise coming from the desktop system fan or from the hard drive.
    If you hear like a clicking noise coming from the hard drive you may need to run diagnostics on it to check if the hard drive is failing. check with your computer manufacturer is your system still under warranty for parts replacement.
    Keep me posted.
    Thanks
    Nov 18, 2008 | Gateway Computers & Internet
    The monitor turns off and on repeatedly.
    There is a loose connector on the cable or the cable attachment on the PC board. Jiggle the connector as its connected and see if this causes the LCD to fire up.
    Sep 01, 2008 | Dell 1503FP 15" LCD Monitor
    Computer making noise
    Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
    Cause: This issue could be caused by any of the below possibilities:
    1. Monitor degaussing.
    2. Monitor changing resolution.
    3. Monitor syncing with the video card.
    4. Monitor warming up.
    Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
    Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
    Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
    Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
    Additional information:
    • See document CH000302 for additional information and other noises that may come from
    Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
    Hannspree HANNS-G 19" Widescreen Monitor Logo
    437 people viewed this question
    Top Hannspree Computers & Internet Experts
    tomar33
     Chuck N
    Chuck N
    Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
