Question about Canon imageRUNNER 5000 Copier
E007ON IR2016(FUSER FILM OFF TRACK AND WILL NOT REPAIR ITSELF)
You need to replace fixing film there is no way to make remedy?because the edge of the film is not in proper position
YES I REPLACE THE NEW FIXING FILM STILL I AM GETTING THE SAME ERROR E007 AND THE FIXING ASSEMBLY CANNOT GET HOT(ANY PROBLEM WITH THE THERMITENCE?) OR I MUST CLEAR THE ERROR TROUGH THE SERVICE MODE? YOUR ADVICE WILL HIGHLY APPRECIATE SINCE IAM CONFUSE.
P.S:whhat i see to access the service mode of a Ir 2016 is so differnt to IR 2200canon.please any help to known how to access the sav mode of ir 2016.thanks in advance
  • lukanzu Dec 19, 2008
    perfect it work now!many thanks
    let us keep in touch.
Oh.....
the fuser film sleeve of IR 2016 and IR2200 are the same size.
please check the other reasons...
Posted on Dec 17, 2008
My machine iR2016 is showing system error e007. wahat should
DEAR
THE PROBLEM IS DUE TO WORN OUT OF FIXING FILM ASSY.
YOU CAN REPAIR IT BY CHANGING THE SLEEVE OR REPLACE IT.
THANKS.
Dec 30, 2014 | Canon Office Equipment & Supplies
What is remedy error code E000007-0000 for canon imageRUNNER 2422/2420
A E000007-0000 means that the fixing film is out of "HP" The fixing film has a white patch that is the home position and as the film is turned, there is a sensor that reads it in & out of "HP". Odds are that the film is ripped on one side and the film moved toward the front of the copier and the sensor can not read the patch. You will need to replace the upper film unit or the whole fuser unit to repair the problem.... Good Luck
Sep 18, 2012 | Office Equipment & Supplies
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
System error E007 ir2016
i"m sure that the fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one
Dec 15, 2010 | Canon iR 2016i Black and White Copier
Canon ir2016 error e007
the e007 error means Fixing film rotation error
the fixing film in the fuser unit is not rotating or is defective.
Solution is to change fixing unit , part number: 3FFM2-3352-00000 (STK FIXXING ASSY)
Hope it helps.
adi
Nov 05, 2010 | Sharp AR-M350N Copier
How can i do if my canon printer ir2016 display system error E007 on screen
these is fixing film error code, to get rid of it, you need to change fixing film.
.... call service!
Aug 13, 2010 | Canon iR 2016i Black and White Copier
Hello the problem is in my canon IR2016 showing
That means that fixing film ( Folie ) is worn out. Replace fixing film assy.
Jun 14, 2010 | Sharp AR-M350N Copier
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Eoo7 on ir2016 how to solve the problem
hi
you need to replace fixing film there is no way to make remedy?because the edge of the film is not in proper position
Dec 13, 2008 | Canon imageRUNNER 5000 Copier
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
680 people viewed this question
Clive
Clive
old marine
old marine
