Question about GE XL1800 1100 Watts Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
Anytime I try to cook something for more than a few minutes (say, making rice in the microwave or defrosting something), the microwave just shuts off mid-heating, then comes on again some 20 minutes later. When the door is opened it is often very steamy inside, indicating to me that some overheating sensor has been tripped. This model has the built in fan, and the door does open during heating and the fan sounds like it may be running, it just simply isn't cooling the microwave or removing the excessive steam. I did not install this microwave myself, so I'm hoping to get some advice on where to start looking for the solution before I start tearing apart my new kitchen! Thanks, Matt
  • 2 more comments
  • Matthew Ring Mar 20, 2007
    Thanks for the response bassplayer. I'm thinking it may not be properly ventilated, but am I not right in assuming that if the front vent cover opens and closes when heating that it is working? Where else does there need to be ventilation?
  • bjimswife Jun 20, 2008
    Samsung microwave gets steamy inside and will turn off. Once cool it will work again (limited). I do not hear the fan that I normally hear running during operation.
  • djmangus Aug 24, 2008
    when cooking on high for several minutes- baking potatoes for instance- M icrowave loses power. no lights or fan-nothing. After about 10 to 15 minutes a clicking sound is heard and microwave displays PF. then it is ready to use again. Microwave was in a house when we bought it and after this started happening contacted dealer and another brand new hotpoint was installed. Same results. The fan is venting out of the house when using but it still shuts off.
  • Anonymous Mar 19, 2014
    It shut off while I was cooking and wont come back on
  • 38 Answers
First of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Posted on Mar 20, 2007
My GE OTR Microwave Model # JVM3670SK02 overheated when I tried to cook rice for 30 minutes...two times in a row. What could be the problem?
why are you cooking rice for 30 minutes in a microwave????? the problem is that a microwave IS NOT A RICE COOKER!!!use a rice cooker or use instant rice and heat the water for 2 1/2 minutes only!! OR BURN DOWN YOUR HOUSE!!
May 08, 2015 | GE Microwave Ovens
I just bought a new rice cooker container for my family to cook rice. It saids use one cup of rice with 1 and a half of water and microwave for ten minutes. Then thought I use 3 cup of rice then must...
you do not need to triple the time when tripling the quantities, example: one baked potato = 8 min, 2 = 10 min,3= 12 min ....
sounds like a triple batch is a bit much for your microwave
so you may want to cut it in half
Feb 09, 2015 | Microwave Ovens
How to make rice
Cover with the lid and turn the heat down to its lowest setting. Leave it alone - once the lid is on, set the timer and go away! If you lift the lid and let the steam out you can slow down the cooking process, and rice should always be cooked as briefly as possible. Give white rice 15 minutes and brown rice 40 and use a timer - overcooking is what spoils rice. The best way to test if it is cooked is simply to bite a grain. Another way is to tilt the pan and, if liquid collects at the edge, it will need a couple more minutes' cooking.
May 31, 2014 | Emerson Microwave Ovens
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Magic Chef MCD11E3W Just Dies While Cooking
There is an internal cooling fan. Sounds like your s has failed and its thermal cut out is turning it off. Take it for professional repair. You can't open microwaves as they have special security screws, plus there is high voltage and dangerous compounds plus the radiation itself.
Feb 13, 2018 | Magic Chef CMV1000B Microwave Oven
Daewoo built in microwave..when making popcorn or anything that steams a lot, like bacon, it shuts itself down and stays off completely for about 15 minutes...then comes back on like nothing happens,...
Your microwave has a Humidity Sensor and is designed to shut down when too much humidity collects in the microwave. It will start again once humidity level has decreased. Wipe down the inside of your microwave often. If there is already moisture in the unit before you cook pop corn, you're just adding more humidity to it. If this continues to be a problem, I would contact the manufacturer for resolve. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 29, 2009 | Microwave Ovens
Shuts off after cooking a few minutes
Since it's under warranty, I would check with MayTag or a local Maytag-authorized servider: http://maytag.com/support/service_parts.jsp
Apr 23, 2007 | Maytag MMV1153A Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
517 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
