Question about GE GSS25LGM Side by Side Refrigerator
Defrost timer sticking
I need to replace the defrost timer in my refrigerator. I found the DEFROST THERMOSTAT, but not the timer. My model is a GE. The number is GTS22KCMBRBB. Can you locate it for me in the diagrams because I can't.
    Scholar:
  • 111 Answers
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
Posted on Dec 16, 2008
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
GE fridge not cold.
If the coil (in the freezer) is icing up then it's not being properly defrosted on a regular basis, ie. 2 - 3 times a day. On older models it's usually just a simple matter of replacing the defrost timer. On newer models, the defrost timer is integral with the 'motherboard', so the whole (expensive Chinese made) motherboard must be replaced because they're not serviceable.
Less likely (but possible) are the defrost heating element and/or temperature sending unit found on or near the coil itself. Least likely is a low refrigerant level, which would indicate a leak.
Mar 27, 2014 | GE Refrigerators
The refrigerator won't keep cold and the fan is not working and there is ice in the unit.
the defrost timer or heater needs replaced you can turn the timmer manually and see if it defrosts it is a round white knob sticking out of the timer box
Oct 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our GE GSS25JFMBWW refrigerator is not keeping cold on the refrigerator side, but is keeping pretty cold on the freezer side? Any idea on what is happening?
Sound like your refrigerator is experiencing a defrost problem. Mot times this involves the defrost heater part number WR51X10055 Look into the back wall of the freezer compartment and if frost is beginning to stick to the back wall unplug the refrigerator and remove the rear panel in the rear of freezer. Defrost with a hair dryer until you can see the defrost heater below the evaporator coils. If burned out it will be easy to spot because the defrost element is inside a glass tube. The defrost thermostat could also cause this problem if defective. If you replace the defrost heater I also recommend that you replace the defrost thermostat part number WR50X10054 There is no defrost timer on your model. Defrost is controlled by the mother board, Let me know what you find, Thanks, Sea Breeze
Sep 26, 2009 | GE Refrigerators
Freezer coils freeze up solid with ice and have to be defrosted manually
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | GE Refrigerators
Ge frig does not freeze on freezer side
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Ge side by side is freezing in the back of freezer, I have to defrost once a month. How do I check what parts I need and how to fix it
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge not cooling well, frost in freezer,back wall and coils
Aug 17, 2009 | Refrigerators
I have a GE GSS201EMAWW that won't defrost, is it most likely the board or heater ??
Jul 09, 2009 | Refrigerators
GE GSS25LGM Side by Side Refrigerator Logo
305 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
