Question about Sony NW-E105 MP3 Player
We have restored the default settings and now encounter ''Format Error''
  • 8,596 Answers
Turn on the player, and press your menu button. Scroll over until the option displays "format", and then select Atrac3.
-Tha Mp3 Doctor
Posted on Dec 16, 2008
If anyone can help me thank you forever. I have a PSP GO and suddenly appeared to me a message saying: can not read storage system please try to format storage from system settings. when I try to format I...
You need to call Sony. Since it is a PSP Go, chances are you are still under warranty. If you are not under warranty, they will usually fix it for cheap money.
Try this first: Go to Settings > System Settings > Restore Default Settings and then try to format it.
Jun 18, 2011 | Sony PlayStation Portable (PSP) Console
Tip
System Restore Via Recovery Console
<br /> Ever encountered a problem with your computer wherein it gives you an error page saying that a certain file in the registry is missing or corrupt? Unfortunately, with this kind of error, there are times that you are not able to boot into the OS, and therefor you are not able to do a system restore. <br /> If you are using Windows 7 or Vista, you may initiate System Restore via booting into "Repair My Computer" which you can choose via the Advanced Boot Options of Windows. However, what do you do if this does not work, or you are using Windows XP. <br /> Fortunately, there is still a way to be able to restore your system. This involves manually doing the system restore via the recovery console (for XP), and recovery environment (Vista and 7). The only thing that you will need is the OS CD. <br /> Once you have successfully booted into the Recovery Console, type in the commands below and make sure that you press "ENTER" after each line. <br /> <br /> C:\WINDOWS] cd \ C:\] attrib -h-s "system volume information" C:\] Cd "system volume information" C:\system volume information] cd _resto~1 ..._resto~1] dir --- this should list several rp folders [short for restore points] just select second to the last or any of your choice other the the last rp folder ..._resto~1] cd rp# ...rp#] cd snapshot ...snapshot] dir --- the 5 hive files are shown in this format: _registry_machine_software _registry_machine_security _registry_machine_system _registry_machine_sam _registry_user_.default Syntax [Command filename location] ...snapshot] copy _registry_machine_software c:\windows\system32\config\software ...snapshot] copy _registry_machine_system c:\windows\system32\config\system ...snapshot] copy _registry_machine_security c:\windows\system32\config\security ...snapshot] copy _registry_machine_sam c:\windows\system32\config\sam ...snapshot] copy _registry_user_.default c:\windows\system32\config\default ...snapshot] exit <br /> After this, you just need to restart your computer and it should be working fine.
on Jul 25, 2011 | Computers & Internet
I want nokia 3600 slide phone format number
there are two method of doing hard format on most of the nokia devices.
1.MANUALLY
1. go to menu and search for setting option.
2.enter in setting menu and search for restore factory setting option.
3. when you press on restore factory setting it will ask you for code enter 12345 the default code.
now you are done.
2.USIN
G CODE
DIAL *#73
70# on main screen.a menu will pop up like restoring all data press ok enter 12345 default code.you are done now.
TO RESTORE SETTINGS ONLY.
USE THE CODE *#7780#
always use fixya to fix every thing
Feb 15, 2011 | Nokia 3600 slide Cellular Phone
Ps3 error code 801301182
ALL YOU HAVE TO DO IS TO GO TO SYSTEM SETTINGS,UNDER SYSTEM SETTINGS, GO TO DEFAULT SETTINGS OR PUT OFF THE CONSOLE AND PUT IT ON AGAIN,HOLD THE POWER BUTTON, IT WILL MAKE A SOUND TWICE,ON YOUR T.V SCREEN SOME SETTINGS WILL APPEAR LIKE RESTORE SYSTEM SETTINGS, FORMAT HARD DRIVE. CLICK ON FORMAT HARD DRIVE, AFTER DOING THAT YOU HAVE TO UPDATE THE CONSOLE.
Jan 09, 2011 | Sony Video Game Consoles & Games
Restarting very often
try restoring settings of you phone. navigate to settings and find restore factory settings, when selected it might ask for your security code, the default is 12345, if you havent changed it yet.
if the problem isnt still solved that way try this
Normal Reset
Using the *#7780# sequence.
It will restore ini files from ROM keeping all your data (themes, 3rd party applications, video, photos, and music files)
Deep Reset
Using the *#7370# sequence.
Completely format phone memory. Default files are cleaned up and rewritten.
Note that data found on memory card will not be altered
Jun 06, 2010 | Nokia E63 Cell Phone
When i click the restore button into itunes, it
The shuffle has been plagued by this error code in the past and it used to mean death. Apple has put an update or "fix" for the error code.
http://support.apple.com/kb/HT1238
or if that is not successful, you can do this.
Here is a fix that will work in almost 1418 cases. Low-level format the iPod using a low-level formatting tool. The default format command in XP will not cut it. You will find plenty of freeware and trialware tools on the net. Here is one: http://hddguru.com/content/en/software/2006.04.12-HDD-Low-Level-Format-Tool/
Just install the application and run it. Choose your iPod “drive” and let it do its thing. After the low-level format is complete, run iTunes and when it prompts you to restore the ipod, do the restore and your iPod is now good as new !! I hope this helps and good luck!
Please remember to vote 4ce5b8a.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Security code for restore factory settings
12345 s the default security code for nokia....if u forget the code then do one thing..better re install the firmware....all ur settings ll come to the factory setting position...but make sure u have all the contacts as it ll get erased during the process.......
Oct 08, 2009 | AT&T LG CU515 Cell Phone - Black
Ok, but i try to change my headphone/earphones or any compatible accessories but still poblem is encounter.
try restoring the handset to facotry defaults which is in settings----->restore factory settings
Jul 08, 2009 | Nokia 6300 Cellular Phone
Sony NW-E105 MP3 Player Logo
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
