SOURCE: dimetic RM2652 refrgerator problem
Check the coils to the left of the burn chamber they should be hot not as hot as the burn chamber but hot to the touch. If not you could have blockage in the coils not allowing the fluids to flow. Also check that the flu area is clear no nest of any sort wasp or birds.
SOURCE: Dometic RM2652 will not cool on A/C or Propane
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
SOURCE: My Rm2652 Refrigerator in my Rv just quit cooling.
You need to have 12 volt supplied at all times to make it work
Check to be sure you have a good 12 + and a good ground.
Lots of times the coolant leaks without you smelling anything Slowly over time
SOURCE: 98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
SOURCE: no ignition
Remove cover from igniter (follow thin wire from electrode,back to it) and test for 12 VDC at + terminal on igniter box. If you have 12 volts at + terminal, replace igniter box.
We are fulltime RVers and the unit has been on since arriving at our present job 2 months ago. did have storms, but no indication of a a lighting strike.
