Question about Compaq Presario Notebook
Decrese in brightness
Iam using COMPAQ (presario 2800) with WINDOWS XP (home edition)
when i insert the powercord pin the brightness of the moniter will decrese,if i plug out the power cord the bright ness will get increse what is solution for this problem?
  • 3 Answers
Did you checked the settings in BIOS. I think you should have adjust some settings in BIOS.
Posted on Dec 16, 2008
I have encountered a problem while installing Windows XP over Windows 7 on my laptop Compaq CQ62-410-US
Most likely you will have problem trying to install windows XP in a windows 7. It is better to use a virtual machine on your windos 7 instead. Windows XP mode will not work on a Home edition of Windows 7. you can download the Virtual machine in this link: http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=4580
Once you have downloaded and install this run it. then install the XP on this mode by -run the virtual machine -go through the setup -insert the installation disk -wait for the installation is complete
Then every time you will run the virtual machine it will go to the XP that you installed.
hope this helps
Jun 27, 2011 | HEWLETT-PACKARD HP Compaq Presario...
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Compaq Windows XP Home Edition Presario 700 Startup>Start Windows normally>Windows could not start because the following problem is missing or corrupt:WindowsSystem gaoem.fon I don't have a disk...
compaq has a restore directory on the drive
turn on computer boot in safe with command promp
type in restore it should boot
failing that insert original floppy and it will ask you to pick an option '
Jul 31, 2009 | Compaq Presario 700 470024-192 Notebook
Not running on Windows XP Home Edition
clean the lens. check the settings which provied
Apr 19, 2009 | Computers & Internet
Brightness decrese when i plugin the power cord.
Check your power settings, where the little battery is in your righthand lower tray,look for change screen brightness or something like that,there should be 2 columns, make sure u pick the one that says"plugged in" instead of the while running on battery setting.Adjust accordingly.
Dec 16, 2008 | Compaq Presario Notebook
When i insert the powercord the bright ness will get dim
Its not a problem, its how it was designed. With the power cord in it will be at full power so it will light brighter, When the power cord is out, it will be less bright as its using power from the battery , it will light dimmer to conserve power.
Sound Driver of a Compaq Presario C700 Notebook PC
Take a look to this link, it will be useful for you!
http://answers.yahoo.com/question/index?qid=20080224090934AAA1iAK
Nov 20, 2008 | Microsoft Windows XP Home Edition
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Need wifi driver for presario c754tu with xp pro support
HI ,
Listen dear compaq c700 models does not support windows xp , so i suggest you to please install windows vista home basic minimum.... all the drivers needed by this os is available on www.hp.com..... hope you must be satisfied otherwise no solution is dere....
b.bye
May 10, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario Notebook Logo
210 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
