Need external antenna for Nortec Navigator No. E-GPS010
I have looked everywhere I can for an external antenna for the Nortec Navigator GPS Modle No. E-GPS010. the Tech with Nortec says this is what I need, but unfortuneatly they nolonger have the antennas in stock and do not expect to get anymore. I was told by a service rep that Sirius had them, but I could not find one on their web site. I think the unit no is 136210. could you help me please?
SOURCE: antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Posted on Dec 06, 2007
SOURCE: connect sirius fm adapter to 2008 honda civic sedan radio
Yes. Factory installed radio.
Posted on Jun 19, 2008
SOURCE: SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Posted on Aug 12, 2008
  • 3 Answers
SOURCE: Sirius Antenna
There are several ways to tackle this problem, most of which would involve getting to the back of the radio, but before you do, make sure you have an "antenna extension cable". Then plug in the 'extension cable to the radio/sirius unit' leaving the other end to 'hang out' where you can then get access to the 'extension' cable. Then you can plug in the existing antenna when you're not using the camper or plug in new antenna that gets clear view of the satellite. Depending on your location and general direction of travel you may be able to use a 'home unit ' antenna on your dash as I do and it works very well. In my truck I often use a home antenna also, although I also have the large unit that bolts to the (tractor) truck mirror assembly.
The other solution is to find a CB repair place (often at truck stops) that is familiar with repairing, satelite antenna wire and pucks. Have them split the wire and place a male and female plug to accomodate the extisting antenna and the new antenna. This service will cost you about $30-50.00 They should find the parts needed at a satellite radio store that sells marine/business/home antennae systems. The parts are not all that common - or the CB fellow may connect male/female connectors that are unique to your truck situation - then any connectors will work but only on that truck of yours. -- Frank
Posted on Sep 16, 2008
smarthome2
  • 1114 Answers
SOURCE: Constantly goes to "linking" whenever I select Sirius. Sirius tells me that means an antenna problem. However, I have tried a new antenna with the same results.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
Posted on Jun 03, 2009
Receiving a no gps signal. please move to an open area message on my Blackberry 8350 smartphone. Have never experienced this issue before. I cover a large geographic area and am dependent upon my...
Sounds like an antenna problem. Some units have internal antennas and some have external ones that plug into the unit with a small cable. The unit thinks you are still inside and cannot find a satellite to lock on to.
Oct 20, 2013 | Tomtom GO 910 GPS Receiver
IS THERE A EXTERNAL ANTENNA AVALIBLE . IF SO WHAT MODLES CAN I USE THANKS MODLE 1623 FURUNO .
I would assume you're talking about the radar? it's a RSB0093-074 it's just for the 1623. There are no other options. If you're referring to gps antennas then any antenna that outputs nmea can be used.
Jan 25, 2010 | Furuno 1623 Radar 16nm Range
I need to update my gps how can i do that
Read this post from a previous fixya question.
http://www.fixya.com/support/t392324-nortech_navigator_e_gps010_map_updates
hope this will help, sounds as if it is hard to get updates for this brand.
Good luck.
Aug 27, 2009 | Navigator E-GPS010 GPS Receiver
Navigator locking up
take it back to sams club & insist on your mony back if they can not get intouch with nortech or get the dept. head to swap it with a useable product
Jan 05, 2009 | Audiovox NVX226 GPS Receiver
Nortech Navigator E-GPS010
I need to replace the car power cord as there must be a short in the wires. I have changed the fuses but that did not help. Where can I find a power cord so I can use my gps. It is only about1 1/2 years old.
Jun 02, 2008 | Audiovox NVX226 GPS Receiver
Nortech Navigator e-gps010 map updates
You can contact Ferro Works and they will send you a new CD with maps on it. They were not very clear on how updated the Version is. I called them and had a commitment of a new CD to be sent to me within fifteen minutes of dialing.
Here is the Info
619 Slack Street
Steubenville, OH 43952 USA
Tel:866-578-0101
E-mail:service@ferro-works.com
Feb 12, 2008 | GPS
I emailed ferro-works.com and asked about if they could email a update or a link and they replied the latest map update for the e-gps10 is 2006, Mine says is was manufactured 10/2006 so it looks like they made it upgradable and havn't bothered to upgrade it yet if they plan to at all. A posting on the web said you could buy a Destinator upgrade, I looked and I couldn't find one for Nortech and the others were $99. I paid $99 for the navigator on discount so I wouldn't pay another $99 for a upgrade myself.
Jan 19, 2008 | Audiovox NVX226 GPS Receiver
GPS Car Power Cord Replacement
Any cigarette lighter 12 volt power adapter will work, as long as it fits. Take your unit to Best Buy, Fry's, Walmart, or Circuit City and match the plug that goes into the unit to a new one. The other end will plug into the car lighter socket. Check the gps section of the electronics department. They will have one that works.
Nov 07, 2007 | Audiovox NVX226 GPS Receiver
67 people viewed this question
 Grubhead
Grubhead
