Question about Goodman Heating & Cooling
GMP050-3 heater, gas turns on and lights for 5-7 seconds and just as thr igniter goes dim the gas shuts off. after 3 cycles the erd LED flashes on/off at a 1.5 seconds on and 1.5 sec off Gary
    Problem Solver:
  • 12 Answers
After the gas turns on, it is the flame sensor's job to see that ignition took place and send 24v to the gas valve. If it does not do this, the gas valve shuts down as a safety precaution. After 3 tries, the furnace will go into "lockout" and will not let it attempt to start again. The lockout can be resolved by turning off the power to the furnace for a couple minutes and then turning it back on. Sounds like the real problem is a faulty flame sensor not sending 24v to the gas valve. Sometimes they can be cleaned with a piece of sandcloth. This will cure failure to recognize the flame due to carbon build up on the sensor. Otherwise, the sensor will need to be replaced. Hope this helps!
Posted on Dec 16, 2008
I have a jandy LT200 propane heater which doesn't turn on. When power is on the lights on electronic board all flash once and then go off. 2amp fuse going to transistor is fine, not blown. I replaced the...
If this heater is hooked up to automation check the temperature reading on the indoor remote. If it reading over 104 the sensor is bad and the heater will not fire thinking that it is at set temp.
Oct 29, 2013 | Jandy Laars Lt 250,000 Btu Heater
Ignition control failure
Try cleaning the flame sencor first , or it could be the snap dice shutting down there are two on there you could bridge them out one at atime and see if it stays on .
Nov 22, 2012 | Mr. Heater Natural Gas Garage Heater -...
Reset change engine oil light
Information taken from: http://www.idavette.net/tech/oilreset.htm
[quote]
The "Change Oil" indicator is reset by using a sequence of Driver Information Center (DIC) key presses as follows:
1. Turn ignition "ON", but do not start engine. (ALDL pin "G" should NOT be grounded.)
2. Press the "ENG/MET" button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of Step 2, press and hold the "GAUGES" button. While the button is held, the "Change Oil" indicator will flash.
4. Continue holding the "GAUGES" button until the "Change Oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds.
If it does not successfully reset, turn ignition "OFF" and repeat the procedure from Step 1.
[/quote]
Nov 16, 2009 | 1991 Chevrolet Corvette
5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
May 26, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Rheem powervent2 water heater not starting
I am guessing that their is a flag control(switch) in the airstream of the vent and it is now stuck in the closed position due to the snow, maybe. Find the flag switch and make sure it can move freely. It must move freely for the venter fan airstream to operate or move it.
Jan 24, 2009 | Water Heaters
RUUD heater
Sounds like a dirty flame sense rod. Be sure to shut off power before removing the rod and cleaning it with sandpaper or steel wool. Do not touch or disturb the hot surface ignitor or you may cause it to fail.
Dec 27, 2008 | Heating & Cooling
Heating & Cooling Logo
231 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
