Question about ASUSTeK P5K Desktop Board - Core 2 Extreme Quad-core, Core 2 Extreme, Core 2 Quad, Pentium D, Pentiu... Motherboard
Asus p4ge-mx on booting i get message microprocessor changed press f1 to continue or del to enter setup every time when i boot the system once it is shut down and mains is shut off. the mb is asus make p4ge-mx
    Sergeant:
    Champion:
  • 250 Answers
The onboard battery that keeps the CMOS or BIOS settings is bad. It's a large flat battery that looks a lot like a watch battery just larger. Carefully remove it and get a replacement. Numbers for the replacement should be on top of the old battery.
Posted on Dec 16, 2008
Asus delete password bios
PRESS the DEL key on boot up.... you will enter setup. Pending your computer .... it may be F1 or F11.... normally your shown what key to press at boot up (but the manufacturers (hide the on screen messages during boot up) so turn on this feature as well, because you get to see your system boot. Laptop and Notebooks have simple setups whereas more advanced motherboards like Asus give you a full array of options to control your PC.
Aug 15, 2014 | ASUS K50IJ-C1 Notebook
In doing a system restore i managed to wipe out windows in my el1852w ..now the screen says,install windows..X Windowscould not complete the installation.to install windows on this computer restart...
As PC starts watch screen for message "to enter setup press del" or similar. (press F!, press F2, press F12).Power down the PC and then power it back up. Be ready to press the KEY to enter setup while message is on screen. If you do not see the "enter setup" try holding the delete key as machine powers up.
Then repeat while holding F1 key etc. Once you enter setup (CMOS SETUP) find the boot settings and select CD as first boot drive. Put your full install CD in the CD drive have the license code ready. Example; AB123-1RD5C-XP94D-MN47G-LRIPQ. Your key will be on the CD sleeve or license sticker on PC. With install CD in drive power PC up. The PC should boot from the install CD. Do a full install on C drive. This should format your C drive erasing everything on drive C. Format with NTFS (new technology file system). During install the PC will restart a few times. At one point it will require you to type in license code. About half way thru install you will be instructed to remove all disks from drives, at this point you enter setup (CMOS) again and change from boot from CD as first choice TO boot from HD and second choice boot from CD. If you can not complete install you may have a hardware problem. GIVE plenty of time for each install step. Install may appear to have stopped but it will continue when it has completed that step.
Oct 19, 2013 | eMachines Recertified - EL1852G-52W...
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
ASUS p4 intel motherboard giving chassis intruded. fatal error message and system would not boot unless reset again. can anybody solve this?
Hi there.
Start the PC and enter the bios using either the Esc or Del key, once in the bios set the chassis intrusion to "disabled" save the changes and exit the bios, the computer will now restart and you should be able to boot into the operating system no problem.
Good luck and thanks for using FixYa!!
May 01, 2009 | ASUS P4GE-MX Motherboard
BOOTING PROBLEM
Hii, Go to the BIOS setting by pressing DEL at the system startup and then set it Default and then save setting.
Feb 22, 2009 | Gigabyte Computers & Internet
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
ASUSTeK P5K Desktop Board - Core 2 Extreme Quad-core, Core 2 Extreme, Core 2 Quad, Pentium D, Pentiu... Motherboard Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
