Question about Philips Televison & Video
Magnavox 6P6030W101 has red display, then turns off
We bought this tv off Craigslist for $50. The problem appeared to be convergence chip(s), and I figured it to be an easy job. I have an electronic engineering degree - I'm pretty confident around electronics. Anyway, the guy had the tv in the back of his truck fro who knows how long. It's been in the single digits here for days. He had the tv covered, but it didn;t matter. When we brought it into our house, it apparently started condensating pretty badly on the inside. Like an idiot, I turned the thing on about 10 minutes after we got it in the house. I heard some popping and crackling, but no burned electronics smell. I pulled the back of the TV off and used a fan to sirculate air in the tv cabinet for several hours. Once all condensate was gone, I powered the TV back up, and all we get is a red picture. If I adjust the 'screen' adjustment for the red CRT (inside the cabinet), it gets brighter and dimmer, but not as it should. It only flickers when I turn the knob - doesn't increase and decrease lineally. If I turn either the green or blue adjustment clockwise, the TV will work for about 45 seconds (the B and G CRT's will light up), then the picture shuts off. I know I have a bad convergence chip because the picture was bowing down from the top and up from the bottom last night when we looked at it at his house. From what I have read, the CRT's are not bad... but I need to find out what could be wrong (read: smoked) to determine whether I should look for another TV or fix this one.
    Problem Solver:
  • 8 Answers
Always check the power supply first. I'd go ahead and replace all 3 convergence ic's and then start at the voltage reg. in the power supply. get the part number of off the V reg. and go to Click here: Electronic Components Supplier-Catalog-Cross Reference-NTE Electronics and you can cross that number and get the pin-out to find the V output. Check to see if you have about 130 volt on the output leg. it its a lot higher than 130v,or none at all, thats what I would replace.
See what's free at AOL.com. voltage reg. and go to
Posted on Dec 17, 2008
It appears to be convergence issues. Red, green,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Display's Multiple shadows/images on screen
Ur convergence is dead.Must replaced 2 convergence ICS,and some or all it resistors.Must know how to solders?Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will $300 for parts and labors.
Mar 09, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The screen has a blue like tint around the edges of the screen..what can i do? it's a magnavox 6p6030w101 60inch projection tv.
you have coolant in your red, green, and blue picture tubes. this coolant will start to turn dirty as time goes. the coolant should be clear but when it starts to turn, your picture has like a haze in it. coolant needs replacing. suggest local service center
Nov 08, 2009 | Televison & Video
Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 55p8288 - Screen slightly bowed and picture too large.
  • Screen looks 3D
Apr 09, 2009 | Philips Magnavox 55P9271 55" Rear...
The red light on the front flashes and tv wont turn on
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Feb 13, 2009 | Philips 51PW9363 51" Rear Projection...
Red "aura" in the middle of my 55" Phillips Magnavox
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 51" Model # 51MP392H/17 Color problems
  • Screen looks 3D
Jan 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
TV turns on only after disconnecting convergence cable to red yoke
Sep 23, 2008 | Philips 50PP9202 50" Rear Projection...
Magnavox rear projection
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
