Question about HP Pavilion dv9000z Notebook
When turning on the computer doesnt response lights on
The lights is on but after a few mins it turns off and back on again but it keeps on repeating that way. I tried to remove the battery and install it again that s the time it works .Is there something wrong with my computer nHP Pavillion DV9000(DV8240nr)
  • 1 more comment
  • let_g Dec 18, 2008
    thanks for your response i think you are very exact about what you think regardingmy problem though i do not know if what ive just updated was the SOFTPACK you are reffering but i;ve noticed this event after an update. i have already talked to HP tech and their advised and assistance was a big help. my laptop seems worming fine now i had just some instances it happen again but after repeating what the HP tech about the BIOS , now its working thank you and i really appreciate your actions
  • Frank Gant
    Frank Gant May 11, 2010
    I've seen this happen when someone tried to install softpack 3. Any chance you had done that?
  • 57 Answers
Ok when I had that problem it eventually quit working altogether.
How long have you had that laptop? I was told by HP that certain dv9000 models have Bad motherboards leading me to believe yours might be going. I recommend going to hp.com and going to support and talking to a HP Technician to see if this is truly the case and if it is get a box there to ship it in and get it fixed.
I had to send mine in when my motherboard went on me.
Posted on Dec 16, 2008
Touch screen not working
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
Tv shuts off, when turned back on, the green light keeps blinking and tv wont come back on. if you leave off for a few min. the tv will come back on. then the tv will shut off again after a few min.
One of two things...first hold power button while you hold the up button on your remote, this will reset your tv to manufacturer's settings....you could have sleep timer on.....if this does not work, you have to replace the lamp, my tv did the same thing and it happened to be the lamp. Hope this helps, good luck
Aug 05, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
The unit suddenly stopped working; contact is plugged in but on-button does not work. No lights on, it does not seem the unit has power.
I faced a similar problem with Mine a couple of days ago.
Try these below
1. Keep the unit plugged to the wall socket (and charge). Green light (indicating charging) may not glow. It doesnt matter. Keep it on for a few hours.
2. Then try to turn on the unit.
3. If it still doesnt turn on, fold the unit and keep it aside for a few mins (say 10 mins).
4. Open it and then try to turn it on.
Mine worked with step 4.
See if this helps.
regards,
Lakshmi
Nov 21, 2010 | Altec Lansing Inmotion-IM600...
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
The part time light is on
start car put it in neutral shift 4x4 lever into 4x4 low then drive a few feet. now shift main trans back to neutral then move 4x4 shifter back to 2wd high for normal driving then shift in drive and drive for a few min light should turn off..if nor disconnect battery for 15 min to reset computer and see if that does it. if that doesnt work you may need 4x4 linkage adjusted ..do you have a lift?
Nov 27, 2008 | 2002 Jeep Liberty
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
HP Pavilion dv9000z Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
