Question about Jwin JX-MP121FM (128 MB) MP3 Player
My mp3 player won't turn on
I just bought my mp3 player. I plug it in to the computer and it turns on. When i slide the usb off the mp3 just so it is barely off the mp3 player turns on and it starts playing music. but when i completly unhook the mp3 from computer it won't turn on again
5 Suggested Answers
  • 363 Answers
SOURCE: wont work
Tell us if this is a new player to you or if this is a new problem.
Posted on Oct 01, 2007
  • 111 Answers
SOURCE: cant put songs onto my daughters bratz mp3 player
When plugging a USB removable device/storage, you should see an icon named "Safely Remove Hardware" in the system tray (right side of the task bar, near the clock). Left click on it, and you should see a list of removable hardware.
If you can not see the device there, then there is problems with your MP3 player, perhaps the battery is too weak; if this is the case, just leave it a few minutes until the device charged and initializes and recognized by the computer.
If you can see the device, but no drive letter assigned to it, then there is problem assigning drive letter to it.
You can re-arrange the drive letter assignment by entering Computer Management console: right-click on My Computer, then click on Manage.
Choose Disk Management, and assign a drive letter to your device.
Posted on Dec 18, 2008
  • 4 Answers
SOURCE: jWIN mp3 player
try holding the play button for 10 to 20 second it's probably come on.
Posted on Jun 29, 2009
  • 1851 Answers
SOURCE: wanting to download music onto
You have to use any available on the net converter to mp3. I suggest Format Factory (here is the link for you to download it from the official site). It's a freeware program and it could be usefull when you need to convert video files too. In two words it convert all multimedia files to all multimedia files. Of course if you'd like you can use any else you want.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
direct FixYa link:
Posted on Aug 24, 2010
  • 32281 Answers
SOURCE: I cannot get my daughter's
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
Posted on Mar 18, 2011
0 characters
1 Points
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
I bought a sylvania mp3 smpk4083 mp3 player and it orgianlly worked with my computer, but now when I connect it to my computer it turns on my player, but won't be regonized by my computer? How do
Same thing happened to me with an IPOD. When I plugged it in to one of my USB ports, it ******** up all the USB ports. I suggest reinstalling the drivers for your USB Ports. Then install the software that came with your MP3 Player before replugging it in. Good luck :)
Apr 01, 2012 | Sylvania SMPK4083 Digital Media Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My son's mp3 stopped playing yesterday. We plugged it into the computer. There's no response from the player and no indication from the computer. the usb ports on the computer work.
Are you plugging it infront or at the back USB port of the computer? Try turning it off first and then plug at the back usb port. Once plugged in, that would be the time you turn the MP3 player on. If the computer still does not detect the mp3 player as new usb device, then i guess the mp3 player must have been fried due to not being "safely removed" from the usb port. Make sure you are safely removing ALL usb devices when disconnecting them from the computer.
Mar 01, 2010 | MP3 & Digital Media Players
How do I charge my daughters amt mp3 hello kitty clip on. when I plug it into my computer do I turn the player on to charge or keep it off. she was kind enough to lose the directions.
G'Day To charge your AMT mp3 player you must first plug it into your PC USB port using the supplied cable. Next turn on the player using the sliding switch on its side.The indicator shows the battery is charging, but it is not. To make it charge you have to turn the player off. To do this, hold down the "play" button until you get the "Bye-Bye" message. The screen will go black and the battery will now charge. Do not use the slide swich to turn off!...woozie. Australia
Jan 18, 2010 | MP3 & Digital Media Players
On the intro screen it freezez and eventually goes to the next screen and says refreshing database but it dosent refresh
This seems to happen when the database gets corrupted.
1. Turn off the player.
2. Plug the usb cable to the computer, don't plug it to the player.
3. Slide the lock switch to the right, you will see an orange strip.
4. Hold the menu button to start the player. Don't release it yet. Wait until a shutdown message appears and the player goes off again.
5. Plug the usb cable to the player end. The player should go on again. The player should mount as a disk on your computer. Find this disk and back up its contents.
6. Format the player, as explained elsewhere.
7. Disconnect the usb cable. This time the database should refresh properly. Once this is done, slide the the lock switch to the left and turn off the player.
8. Turn the player back on. It should work, but you will have to load your stuff again.
9. Redo steps 1 to 5, except that now should copy your music, videos, etc, back into the player.
10. Repeat step 7.
11. Turn the player back on. It should work again.
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
Low battery
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
Frozen SanDisk M240 MP3
It will turn on but freezes at the opening screen. Cannot access the menu whatsoever. I've tried plugging it into USB in the back, removing the battery, sliding the Hold button to the right as advised in forum suggestions but nothing budges it from the opening screen. Also: it does not show up as being attached to any computer I plug it into. Got a fix?
Nov 01, 2008 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
Jwin JX-MP121FM (128 MB) MP3 Player Logo
20 people viewed this question
Top Jwin MP3 & Digital Media Players Experts
isaac johny
isaac johny
mac colar
Are you a Jwin MP3 and Digital Media Player Expert? Answer questions, earn points and help others
